'ntldr is missing' I have windows 2000 pro
'ntldr is missing'
I can't boot
    President:
  • 2,653 Answers
I've used this page for info in the past with lots of success.
Posted on May 25, 2010
Nltdr missing
How To: Fix "NTLDR is missing"
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
Symptoms
When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
Cause
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drives
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
  • Click 2. Windows Recovery.
  • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
  • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
  • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
  • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
Nov 17, 2010 | HP Pavilion dv6000z Notebook
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
Ntldr is missing
These are the common causes for this error Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and/or NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32. New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS.
Please checkout this link for fixing the same Ntldr is missing
Sep 19, 2010 | Computers & Internet
Erorr code 2000-0146 ntldr missing ???
i could give you a long technical solution but the best is to re-install windows and select repair installation ,, it should fix the error ;)
Mar 10, 2010 | Dell Inspiron 1525 Notebook
NTLDR is missing in my computer
Missing NTLDR can be caused by any one of these problems :-
With Windows XP follow these instructions
If this doesn't work, then the last resort is to install Windows again, plus the computers device drivers and your programs.
Feb 11, 2010 | Computers & Internet
I have a Epic notebook ACE 1314 model no. MS_1314 and when i turn it on it comes up with NTLDR is missing can anyone help me please? Cheers Dylan
the windows system is trashed - boot from a xp cd and choose repair -
NTLDR is Missing
NTLDR is missing
Causes:
Sep 10, 2009 | Computers & Internet
Ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current loadTOCNode(3, 'summary'); Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer loadTOCNode(3, 'summary');
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.iniA list similar to the following list appears: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect If you receive the following message, the Boot.ini file may be missing or damaged: The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Jul 07, 2009 | Compaq Evo D500 PC Desktop
Compaq Presario C300 Recoivery Disc 2 corrupt
Hi John.
F11 process is not working and you get a NTLDR missing when you turnon the notebook.
Steps to be performed:
1. Perform hard drive self test from BIOS.
2. If it is passed then use retail version of operating system disk to install XP or try using new recovery disks which nay cost you $15.00.
In your notebook model this issue appears if there is any issue with the hard drive.
Jul 04, 2009 | HP 435768-001 - Compaq Presario C300...
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
NTLDR is Missing
NTLDR is missing
Cause:
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Fujitsu Siemens Scenic T on windows 2000 Pro SP4
to fix it:
u should boot up with windows 2000 cd
go to repair windows then go recovery console from cd rom
now u'r in dos mode:
if u'r cd rom drive is d: and u'r hard disk is c:
just type this:
c:\copy d:\i386\ntldr
it's ntldr not ntdlr
then type:
c:\exit
u'r pc will restart and everything should work fine.
Hope this Helps. Regards Khushroo
Mar 09, 2009 | Fujitsu Siemens Computers & Internet
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
