Question about Microsoft Xbox 360 Console
Xbox360 getting error code e68 - Microsoft Xbox 360 Console
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive.for further help click here for reference
Posted on Dec 17, 2010
    President:
  • 1,099 Answers
When you get the dreaded Disk Read Error, it normally occurs for one of two reasons. Either dust has built up on the lens of the laser mechanism, or the operating voltage of the laser has drifted off slightly due to heat and age. Of course, occasionally there are actual failures of components, which cause this, but these are the main two reasons.
Cleaning the laser lens
Remove any CDs from the unit and unplug all leads and memory cards. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
Take your normal sized Phillips screwdriver and unscrew all the screws.
BE CAREFUL not to damage the eject/power button ribbon cable, as these are very fragile.
Gently lift off the lens casing and you will see the slide tray underneath.
Take a cotton bud and careful place some of the alcohol on it (but not so much that it is dripping everywhere). This alcohol is the same (or similar) to the small bottle of alcohol which is in audio and video cassette cleaning kits. This is probably the best way to locate a source. Locate the lens (the circular glass part) and very gently rub the cotton bud around the lens in circular motions for about 30 seconds, being very gentle. Once done, flip the cotton bud over and dry the lens with the other end for about 10 seconds.
The laser part slides on rods to reach different rings of the cd. These can become clogged up with dirt and dust, making movement difficult. So, take a clean cotton bud and clean the slide rods thoroughly, making sure you get to all parts and give a good clean.
The spin rod controls the movement of the laser and is greased to allow smooth frictionless movement. Clean the surface of the spin rod. If you have some grease to replace with then remove all the dusty grease (or as much as you can) and then apply some fresh grease. If you have no grease to replace with then just remove any excess dirt but try to leave a little grease, as it is required for the mechanism to work.
You have now completed the cleaning process. This often cures read errors and should always be attempted first. Reverse the dismantling process and put the machine back together, making sure you DON’T TRAP the eject / power button ribbon cable, as this can cause serious problems for you if it happens.
14) Power on the unit and try to load both a CD and a DVD game. If all works fine then CONGRATULATIONS on completing the guide successfully. If however there is no change then you should proceed to the next step - Adjusting the Disk Mechanism.
Good luck....
Posted on May 26, 2010
3 Suggested Answers
SDZAKKMF
  • 50 Answers
SOURCE: Im saul reyes from El Salvador
Necesita llamar 1-800-4-myxbox. Ellos ayudan tú.
Posted on Jul 11, 2008
sardanadixit
  • 813 Answers
SOURCE: e68 error on xbox 360 HELP PLEASE
A Working Solution.
Remove any disk from the DVD drive.
Remove the hard drive and turn on. When you get to the dashboard turn it off again by holding the X button on the controller and select 'Turn off console'.
Wait 10 seconds and then turn on again by pushing the X button on the controller. When you get to the dashboard turn off again via the X button.
Remove the AV / Video plug from the back of your Xbox.
Replace the hard drive correctly.
Switch on the Xbox via the power button on the console. 4 red lights should flash.
Wait 10 seconds and re-insert the AV / Video cable.
You should now load into the dashboard with your hard drive profiles - wait theres more!
Turn off and on via the X button as before another 2 times with all leads and the hard drive in place.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again any way you feel like it and it should be cured.
Posted on Aug 06, 2009
Error code 68
Good Morning Mua_m7,
I see that you are having trouble with your Frigidaire washer giving you an E68 error code. The E68 could be one or both of two possibilities.
First, it could be the heating element. If the heating element goes out, this means that you would be unable to get the water temperatures to hotter temperatures.
Second, it could be something going on with the main control board inside your washer.
With you receiving the E68 error code, I suggest that you give your washer a hard reset, by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. When you restore the power, if you are still receiving the E68 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire Washing Machines
Fix E68 error code on xbox360 slim
Hi there elaine try this walk though i have put the link in here for you to to step by step instructions it sounds like the hard drive is gone..
http://www.wikihow.com/Fix-an-Xbox-360-Error-E68
Cheers Nikki
Nov 13, 2011 | Video Game Consoles & Games
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
New halo xbox360 just opened system error E68
Hi here is the error code details>
E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
let me know if you have any further problems or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 14, 2010 | Video Game Consoles & Games
My xbox360 has the 3 red rings and it say e 68
Hi not sure if this helps had e68 on some I have repaired and sometimes it turns out to be the harddrive just unclip the hdd from the side and turn it on without it good luck
Mar 27, 2010 | Microsoft Xbox 360 Console
I have an xbox360 and it has a red light in the fourth player slot
E68 error message? If so, turn off system, take off hard drive, put hard drive back on, turn system back on.
Feb 19, 2010 | Microsoft Xbox 360 Pro System Console
On my xbox360 i got the e68 error message and i took the hard drive out, and then put it back once the xbox was on and i went to memory on the system settings and for my main profile it said corrupted...
can you still access anything else that was saved on your hard drive?
such as demos or anything else you downloaded, etc? generally that means your hard drive has over heated, or worse, crashed. but! you got lucky that your whole xbox didn't crash with it. there is a chance you can save your hard drive and all your files. there is a how to here: http://ezinearticles.com/?Xbox-360-E68-Error-Fix&id=2549596
Aug 06, 2009 | Microsoft Xbox 360 Console
E68
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them **** up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well
more information can be found at http://support.microsoft.com/kb/917874
Nov 29, 2008 | Microsoft Xbox 360 Console
Jul 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
193 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
