Question about Dishwashers
Bottom draw alway ends up with residue water remaining in the draw?
What sort of dishwasher is it.if its a fisher and paykel then that seems to happen a lot its not a problem
Posted on Apr 07, 2008
SOURCE:
Detergent tank will not draw.
Detergent tanks will only draw at low pressure. Switching to low-pressure is done is several different ways with different makes/models. Some pressure nozzles are push/pull, some are twist and some just have a quick coupling and you have to keep up with a low pressure tip (usually colored black).
If it will not draw at low presser, it is either stopped up with debres, or the check ball inside the injector is stuck. The injector is the little device that is just before the outlet where the pressure hose hooks up. These always have a small metal ball, held in place with a tiny spring. This ball is there to prevent pressurized water from shooting back into the detergent tank. The ball and seat that it presses against can get stuck together with old detergent residues, calcified deposits from the water or even rust.
Use a small crescent wrench to take it apart -- or if you prefer, find the right size box end/open end (metric) wrench. Be very cautious as it comes apart because that little spring can leap out and they are hard to find.
I hope this is helpful to you. If it is, please take a sec to rate me. Thanks!
Don
Mar 10, 2012 | Karcher K 391m Pressure Washer
Residue has been remaining only in the glass glasses on the top rack
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 19, 2011 | Dishwashers
The unit runs through cycle fine, but ends with water remaining in the bottom, that has not been drained and dishes are covered with soap residue.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 16, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My maytag is about 2 years old, we recently can't get the residual water after the wash to drain, so there is always water sitting in the bottom of it, it runs, cleans but wont drain all the water. what...
WEll, look for restricted screens on all pump intakes, and look for kinked drain hose. Some water MUST remain in the bottom, but usually not enough to see.
Oct 01, 2010 | Maytag Dishwashers
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric...
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric conditioner section is remaining full of water
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
Grit like residue after cycle finishes.
I had the same problem and it was fixed by switching dishwasher soap. We always used the same liquid soap for years and when this problem came out of the blue (about 8 months ago) I switched to Cascade action pacs with Dawn. It did the trick! No more residue since then. We now are having a problem with the dishwasher not draining (our unit is 8 years old), but the grit issue has been handled!
Aug 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Dispenser still full of water and fabric softener
fabric softener This video will show you how to keep your soap draw clear and how to service the parts
Nov 15, 2006 | Bosch WFL 2463 Front Load Washer
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
