Question about Sewing Machines
Janome 11000SE - the bobin case keeps spinning and won't stay in place. I am on my 3rd one. I just had it in for a check up and they said nothing was wrong with it. They put in a new bobin case though, and now it is happening again and I have smoothed out the edges of the case and put it in and tried it again, but it won't work. The case won't stay in place.
    New Friend:
  • 184 Answers
Once the bobbin case is damaged you need to replace it or the problem only get worse. If you are on your third case then something is not right. This machine does not have that kind of history of problems with the bobbin case. Typically this kind of problem is caused by the thread not being inserted into the thread take up lever correctly. (this is the lever that moves up and down when you sew and you see it at the top when you thread it) There is a small spring gate that the thread needs to pass thru when you thread it, There could be a problem with the positioning brackets that hold the bobbin case in place so I would explain that you feel three bobbin cases replaced is excessive and you need some help in getting the problem corrected.
I have assumed that the dealer is replacing the cases for you, if you are just buying the case and putting in yourself, then the problem may well be the brackets, Good Luck!
Posted on May 27, 2010
Testimonial: "Hi RichSew, Thanks for you answer. But I found the problem myself. I had the thread in the take up lever, but not the other one. Somehow I was missing that sometimes and other times catching it. You can be sure I catch it everytime now!!"
In my Janome Memory Craft 3000 my material got pulled into the area where my bobin thread comes from. I pulled it out. Now my needle is dragging but not breaking on the white piece underneath where you...
I would suggest replacing the needle, make sure the needle is correct for the fabric and thread being sewed.
sometimes when the fabric gets caught in the feed dog area, there are different reasons, I'll list some below
fabric is too thin--needs stabilizer
top thread has some off the thread take up lever
bobbin is turned the wrong way in the bobbin case
needle is damaged--replace needle with correct size for fabric being sewed--and insert the needle correctly into the needle holder.
if these suggestions don't help, I also suggest having the machine checked to see if there is some other problem like timing.
May 03, 2014 | Sewing Machines
Janome 11000se grey screen
Do you know where the manual dimmer switch is located for the screen. Maybe this was accidently turned dimmer. I've seen this happen way to many times to mention....
Machine Tech
Oct 19, 2013 | Sewing Machines
Needle won't move
yes something is wrong with the machine , it needs to be repaired
Feb 27, 2012 | Husqvarna Sewing Machines
I took out the bobin case and now when I put it back in it wont stay. The thread bunches up or the bobin case comes out of place. Any idea on how to get it to stay put?
The manual usually shows a pretty good diagram of how it should be, it snaps in place. Call singer at 1-800-4singer. Or go online at singerco.com and download a manual for free,
Sep 09, 2010 | Singer 5050 Mechanical Sewing Machine
Bobin doesn;t spin
Generally it is a rubber wheel......bobbin winder rubber........different models have different diameter, but Kenmore is a Janome or New Home brand, so see your local dealer..........if you can remove the top cover you will see the mechanism, but if it is a 2 part moulded body, take it in to the shop because you will break things without a service manual.
Janome Dealer Finder in USA........HERE
if elsewhere, google Janome for your own country.
Best Wishes
www.bargainbox.com.au
Nov 13, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Bobin casing
Look in the bobbin area to see where the screw fell out. Check your manual. Sometimes they have a good picture of the bobbin area.
May 05, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
152 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
