Question about Dell Vostro 1000
I need to find a VGA to HDMI pach cable and audo output also
    President:
  • 2,653 Answers
A box like this should work.
You should also check ebay and shop around for the best quality / price around ;)
Posted on May 25, 2010
Testimonial: "your advise was spot on and verry thankfull thank you Pat"
I am not sure how to connect my gifted LG 295 LM Monator to my PC
so it has power ?
is p.c ?vga display output ?
https://en.wikipedia.org/wiki/VGA_connector
is monitor vga input ?
or is p.c only hdmi output ?
https://en.wikipedia.org/wiki/HDMI
if vga on both you need a vga cable
if hdmi on both you need a hdmi cable
if pc is VGA and the monitor is hdmi then an adapter is needed
if p.c is hmdi and monitor is vga then an adapter is needed
suggest figure out video cable standards and then decide on what you need
as shop will need to know what standards are used VGA or HDMI ?
Jan 18, 2017 | LG Computers & Internet
How do I connect my laptop to my led tv?
Is there a HMDI output on your Laptop or a VGA output. Some TV's have a DSUB input source that allows VGA depends on your laptop it could be HDMI if so TV should have an extraz HDMI input on the back and you change the source input on the TV to the HDMI 2 or HDMI 3 source depending on where you plugged in the P.C. . If HDMI you need to buy a HDMI cable.
Sep 08, 2014 | Toshiba Satellite Computers & Internet
I have HDMI laptop and Dell 1706FPVT 17" VGA monitor. I have VGA to HDMI cable and I connected the cable between these two machines but it is not working. Solution, please.
First of, a little bit of explanation.
VGA = analogue
HDMI = digital
The answer seems to be in your question.
it reads "VGA to HDMI". These cables or adapters doesn't work the other way around. I am guessing your cable can only support vga output to HDMI input. And your setup is HDMI output from your computer to vga input to your monitor.
Solution:
Try and find HDMI to VGA cable or adapter. This is expensive.
If your computer has a vga output, use this with vga to vga. You won't get a better resolution by using HDMI to vga.
Or are you stuck with only HDMI output?
There are adapters for USB to VGA too. This could be less expensive. I have one for my friends Apple Air. I am not a "i" fan so I do not have much experience on Apple.
Hope this helps.
May 04, 2014 | Dell 1706FPVT 17" LCD Monitor
What cable do i need to connect my pannasonic viera px-p42g20b to my compaq presario v6642ea
Hi gmickg,
From what i can see your compaq presario has both hdmi and vga outputs the panasonic viera you have both a vga and hdmi input. Therefore you can use both a vga lead or a hdmi lead. Hdmi also outputs audio therefore it is probably a better choice.
Regards,
K
Mar 30, 2011 | Panasonic Computers & Internet
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
I have a Panasonic TC-P50X1 and want to connect my laptop to it. What should I do?
If your laptop has a DVI or HDMI output, then the solution is as easy as buying a DVI to HDMI cable, or simply an HDMI cable, because your TV set uses HDMI as an input. If you have a Macbook, there are Displayport to HDMI cables/adapters available.
However, if your laptop only has VGA output, then you must buy a converter. Why? The VGA output available on almost any laptop is an analog signal. Buying simple cable adapters will not make your TV (which reads only digital signals) read the analog VGA signal.
Oct 03, 2010 | Panasonic Computers & Internet
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Dell Vostro 1000 Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
