Question about Acer TravelMate 2300 Notebook
Acer laptop dead
Am using acer travelmate its fine but i did a small mistake....am connected it to another cpu through lcd card..
means from my laptop back side i got a vga port i gave the connection to cpu vga port from that time it is not switching on atall what happend to my laptop..
plz help me on this....
  • 1 more comment
  • venkiitsme Apr 07, 2008
    thanks advancly
    so what can i do now...?
    but the system is working fine..
    i need send it for repair...?
  • Mike Waldron May 11, 2010
    You,ve damaged the motherboard, by connected output to output. instead of connected out to input.
    Mike @ Compurepair.
    Problem Solver:
  • 11 Answers
Try to take it to anyone who knows electronics to check the motherboad for you, its not a big problem had it been its Malawi I would have done for you.
[email protected]
Mr CPU.........
Posted on Apr 07, 2008
SOURCE:
I am having a ACER TravelMate 5730 laptop. For the past three or four months whenever I boot my laptop it gives a blank white screen. If I reboot one or two times it will be ok and works fine. Sometimes...
2 Solutions Possible.
The connection between the LCD Screen to the motherboard is not connected well and is causing the issues you are having.
OR.
The screen itself needs to be replaced because it defective.
Mar 16, 2011 | Acer TRAVELMATE 5730-6984 LAPTOP LCD...
Hey, i have an acer travelmate 4010 that im restoring for a friend. but i think the backlight is disabled, how do i turn it back on?
hi there
did you remove the panel from the rest of the laptop (ie: plastics, cables bezel) ..
if so, there is an inverter card you have to plug back in (from LCD panel to mainboard), two pin connection and 30 pin connection
here is the link to the service manual -- i hope this helps
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_TM4010_BOOK.pdf
Nov 09, 2010 | Acer TravelMate 4010 Notebook
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
When i press the power button it makes noise and the screen does not show anything
NOise coming from?? Screen do not show anything is Possible problem of LCD, LCD BULB, INVERTER, CPU, MEMORY, OR GRAPHIC CARD. Issue. Try external for make sure if you get picture Your GRAPHIC CARD, MEMORY, CPU is fine.
If sound is coming from FAN system, That is need to be clean(or Change), Or HDD makes sound that is Coming to DUE.
JMC
Aug 15, 2009 | Acer TravelMate 2355 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
Acer travelmate 292LMI
If you know how to disassemble your PC, check all the connections from the video card, memory card etc. clean the part that you have removed then return it back again. if you're not sure disassembling it, bring it to a computer guy to help you.
Apr 13, 2008 | Acer TravelMate 292ELMI Notebook
Pink/Green Background Acer Travelmate 2410
you are having an lcd experience of the 3rd kind..i'd venture to say your in for a replacement event.
Feb 27, 2008 | Acer TravelMate 2300 Notebook
Acer Travelmate 291LCi problem
how much free space left on hard drive? also check virtual memory settings and finally run scandisk and defrag on hard drive.
Jun 07, 2007 | Acer TravelMate 290 Notebook
Computers & Internet Logo
60 people viewed this question
Ekse
Alun Cox
