Question about Troy Bilt Tb70ss Gas Trimmer
How do I open the spool to restring a Troy Bult line trimmer
  • 404 Answers
They come with a rig pin to lock the spool in place, then turn the large platic ball on the bottom of the trimmer head COUNTER CLOCKWISE. do not try to fill up the spool with line it will only get stuck and melt together. You should also sprinkle the line with baby powder as you wind it up as it reduces sticking too.
Posted on May 27, 2010
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
How do you restring the line on the spool? I can't get the spool off but have managed to rethread it. Just can't figure out which direction the line should be wound.
there should be screws in the corners/middle at the back of the head. Phillips/torx head, once they are removed,you can separate the housing and then you will need to wind the the spool counter-clockwise, note the cord is not attached, once you believe you have wound the spool enough, you will need to feed the cord through, tie a knot, burn the end and the let go of the spool and it will retract the cord, pull a couple of times to make sure the knot is holding, then reassemble and start weed eating. Good Luck Tim
Apr 23, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Have a grass hog that has two lines in the spool. How do I restring the spool
wind in direction of arrow on spool. Use 2 separate pieces. 1 at top and 1 at bottom. Feed 1 through each opening in hub when done.
Apr 10, 2010 | Black & Decker 14" Grass Hog Xp...
Describe string replacement Troy- Bilt TB5755SS
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Have weedeater but no manual to read on how to restring to line
to restring it all you have to do is pop the cap of string head pull the spool out and wind your string around it in the way they say to run it.its usually on the spool wind this way with an arrow.the cap shood be pushed in and turned to unlock the cap replaces the same way
Jun 10, 2009 | Troy Garden
Troy Bilt Tb70ss Gas Trimmer Logo
467 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
