Laptop wont boot up and the screen is black,
Have tried f12 to reboot but to no avail, make toshiba equium around 3 years old....just happened after a power cut yesterday,,,,,,,
    President:
  • 2,653 Answers
Remove the main battery and power adapter, let it sit for about 5 minutes and try booting with no battery.
Let me know what happens, I can help!
Posted on May 25, 2010
Toshiba boot screen won't appear when turned on
It will help if you mention the Toshiba model so we can ascertain which BIOS is running. But in general, take the USB out of the slot, and then when the machine starts up, press F2 when you see the prompt.
Alternatively if you do not see the prompt screen, press the ESC key for 3 seconds immediatley as you start the machine and then F1- that should present you with the Setup screen
Feb 13, 2014 | Toshiba Satellite L855D-S5220 Laptop
Screen goes black
reboot using the key HOLD the key CTRL +F11 OR F12 depend of your computer model use restore factory default. or reboot using disck or USB.
Other wise restart HOLD the key CTRL+F8with network, and use the CHKDSK command for repair.
God bless you
Jun 23, 2013 | Toshiba Satellite P305D-S8829...
How to change toshiba 2000 booupt priority
try holding f2 f10 or f12 this will require up to 3 reboots to figre which one but just hold down one of thse during startup
May 20, 2012 | Toshiba Portege 2000 Laptop AC Power...
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
Toshiba laptop 2 years old, the screen is black. The laptop turns on but get no screen.
You can try connecting an external monitor and if you can get to the CMOS/BIOS you can verify that the active screen is your laptop screen. If everything is OK on the BIOS, then probably your laptop screen is broken. To enter the Bios use F2 or F10 (depending on model) when booting.
Jul 19, 2009 | Toshiba Equium 7100S PC Desktop
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite start up
maybe you lost your COMS you should recharg it
Jan 19, 2008 | Computers & Internet
My loptop doesnt start-toshiba equium a100-306
Try reinstall the OS. or press F5 or F8 when boots AND LOGIN TO SAFEMODE AND DO SYSTEM RESTORE. if are not able to go to safemode, then press del when boots and getinto the bios and check the bootable device is harddisk
Nov 13, 2007 | Toshiba Equium 7100S PC Desktop
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
