Question about Canon imageRUNNER 7200 Copier
Where is the hard drive located on imagerunner 7200 copier? Would like to remove it before disposal.
  • Anonymous Mar 26, 2014
    Copier is being disposed of and has been used for sensitive business information. I need to sanitize the RAM and determine, if it has a hard drive, how to remove it so it can be degaussed.
  • 149 Answers
You have to remove the back of the copier and you will see a large metal box with a few screws in it. might even have a clamping device to hold the cover closed it should be in there. if it is not in there then it is on the back side of that metal box.. just be carefull if you have to remove it.
Posted on Jun 09, 2010
Remove the hard drive from a Toshiba E-studio 450 copier
Dont dispose the HDD if the HDD is still in working condition. U can reuse it on computer, or backup on others copier...
Jun 19, 2012 | Toshiba e-Studio 350 Copier
Where is the hard drive ? Have to remove it for disposal.
Back of the copier behind the scanner rear plate ine the center
Sep 13, 2010 | Canon imageRUNNER 5000 Copier
IR 7200 HEATER SECTION SOUND, & NEARLY HEATER
You need to remove fixing unit and look for broken gears, bushings or security pins on fixing upper roller.
Aug 01, 2010 | Canon imageRUNNER 7200 Copier
Does the Canon Imagerunner c3100 have a hard drive to store copied images?
Hello kaiserma.Yes the C3100 has a HDD.It is 20G.To locate it, remove the rear cover.In the upper right section you will see a silver aluminum box.The hard drive is located wthin it.I hope this helps. :-)
Apr 26, 2010 | Canon imageRUNNER 400S Copier
Counter location
On your contoll panel the is a small button marked with [123] press this button and you will get all the meter readings.
Jan 26, 2010 | Canon imageRUNNER 7200 Copier
HOW DO RESET TONER DISPOSAL FULL,AFTER REPLACING ON A CANON IR 28
You have to enter servcice mode and reset the error code. Press the 'head' key with the star inside it - then the '2' and '8' key at the same time - then the HEAD key again. This must be done fairly quickly and then you're in the service mode. Now, from the screen select 'COPIER' then the 'FUNCTION' key then 'CLEAR' ---->'ERR' ---------> 'OK'. Now turn the machine off and on again. Your code should be gone. If not, you may have to clean the waste toner bottle neck where the sensor light shines through it.
Jan 19, 2010 | Canon imageRUNNER 7200 Copier
Imagerunner 7200 Error E0000532-0001-need help!
hello you have to check the stapler unit and exactly the door loock from bottom under the stapler unit
Nov 10, 2008 | Canon imageRUNNER 7200 Copier
Copier Harddrive
Remove the rear cover. The hard drive is at the top, near centre. Disconnect the connector and remove the four screws. The hard drive can then be removed from the mounting plate. New system software needs to be installed if a new hard drive is fitted to the machine in order for it to operate. It will not function without a hard drive or the system software.
Nov 16, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 7200 Copier Logo
149 people viewed this question
old marine
old marine
