Question about Uniden TRU9585 Cordless Phone
My uniden phone says - out of range
My uniden phone setting on the cradle is saying out of range. I have taken the battery out and put it back in ....still says out of range .....the cradle is charging the phone. The phone is not out of range, because it has been in our bedroom since we purchased it two years ago. The base is sitting in the kitchen.....please advise.....thank you Renee
  • Ellen Moliskey Feb 07, 2015
    mine did the same thing after I had unplugged my base once. Simply unplug the base wait about 10 seconds and plug it back in. Walla and presto! Handsets will work again :)
Uniden wxi477 out of range fix
This problem arises when the handset does not communicate with the base.
These are the steps:
1: Deregistering the handset
2: Registering the handset to base
Deregestering clears the stored (incorrect) base information on the handset.
Reregestering allows the base to assign a new ID for the handset.
Deregistering- press and hold the OFF (red button) and the # button on the handset for 5 seconds. select base unavailable and press OK. Are you sure appears. select yes and press OK. you will hear a confirmation tone. The handset will delete its own base information without trying to contact the base. It will now display MODELS VARY PLACE HANDSET ON THE BASE FOR REGISTRATION.
Registering the handset with the base- Make sure the tel. line and power is plugged into the base.
Press an hold the register button under the base (located between the tel. line and yellow power socket under the base) for 5 seconds until the red light flashes. At the same time press and hold the # button on the handset for 5 secs. You will hear a tone and It will now display REGISTRATION COMPLETE.
If it says registration failed: Retry the registration steps. Make sure the handset have enough battery power. If not charge for 15-20 hrs.
Check your connections on the base and make it is getting power.
The Steps above was my fix for the uniden wxi477 out of range problem.
Good luck.
Posted on Oct 13, 2012
  • Sharon Mosley-Davis
    Sharon Mosley-Davis Feb 24, 2014
    this was very good instructions thank you very much
I just finished fighting my phone for this same problem.Try unplugging the base for a minute and plug back in. I had a dead battery, changed it, it still said out of range. Next I deregistered it by holding the "off" and # buttons until the menu popped up saying "deregister". I had to select "deregister without the base" to get it to work. After all this, I unplugged the base, and that is what solved my problem.
Posted on Dec 29, 2010
Uniden phone searching
the battery should charge from the hand piece cradle where you place the hand set when finished with a call. Make sure you put the hand piece in the cradle correctly and make sure the light on the cradle comes on to show it is charging
Jun 25, 2013 | Lands Phones
Our uniden N32 cordless ph says its out of range..but it is right next to the station. we have replaced the battery, thinking that could be the problem. i have noticed that there is no light on the...
Welcome to Fixya
Try to de-register and register the handset from the base. See procedure below:
Take the phone out of the cradle (charger). Press and hold simultaneously red telephones symbol key and the #key for more than 5 seconds.You will hear a confirmation tone and DEREGISTRATION COMPLETE appears. Now go to the OTHER phone (the MAIN phone). Take it out of its cradle and put the deregistered second handset in the MAIN cradle. The window displays a few messages and then REGISTRATION COMPLETE.
Thank you for using FIxya!
Aug 27, 2011 | Cell Phones
Out of range
Ok. My problem was that the main phone and answering machine worked fine, but the second handset kept saying, "Out of range" no matter what I did. If I tried to make a call, it would say, "Connecting...", but after a while, "Out of range".
I followed the manual which offers two mechanisms to deregister the phone. The first method (press Menu soft key...) went through the motions and then said, "Out of range"!
The second method in the manual worked - after I worked out what the instructions mean!
So here's the answer:
Take the phone out of the cradle (charger). Press and hold simultaneously for more than 5 seconds the red telephone-symbol key and the # key.
You will hear a confirmation tone and DE-REGISTRATION COMPLETE appears.
After that, for me, everything worked.
Jul 08, 2011 | Uniden Cordless Phone
5.8GHZ WITH WIRELESS HAND SET I DON'T HOW TO TURN ON THE HAND WIRELESS HAND PHONE
Is the battery fully charged ? You just put in the battery, put the phone in the cradle, and it does the rest.
Nov 14, 2010 | Uniden 5.8GHz Cordless Phone
Can the phones be left in the chargers continously?
Yes....in fact it's best to return the handset back to the cradle after use.
This is what Uniden says about battery life.
(With average use, your handset battery provides more than ten hours of talk time and approximately seven days
of standby time. You can achieve optimum battery life and performance by returning the handset to the base or
charging cradle after each use. When your handset is left off of the cradle, the battery will gradually discharge even
if the handset is not being used. The actual talk time duration will be reduced in proportion to the amount of time the
handset is off of the cradle.)
Nov 13, 2010 | Uniden DECT 6.0 Cordless Telephone...
Handset out of range
Hello Dmark,
2.4 Ghz is a fairly common household frequency...
Conflict with other systems COULD ALSO
be your problem...
ASSUMING you have had this system
same place, same usage... and have added
NOTHING in your house
(like wireless Cameras, DOT, ECHO, ALEXA, etc.).
There comes a point in the owners of a
DCT758-4 Uniden system's life...
When it is time to check the base battery contacts...
BATTERY charge indicator... and general system
performance;... (battery indicator).
Only the MAIN base is the RADIO BASE...
Depending on battery condition...
You might want to TRY moving your weaker
hand sets around to more appropriate locations...
Failing that...
YOUR BATTERIES ...
(I have shown below) are widely available
from places like eBay and AMAZON...
I am showing AMAZON for informational purposes.
FREE SHIPPING figures PROMINENTLY in my
BATTERY BUYING... So I use TRUSTED SELLERS
on eBay...
(USA: $3 - $5 each (Battery cost for your phone) .
Happy hunting...
Hay un problema muy pequen(y)o.. (not English)
Uniden DCT758 3 DCT Cordless Phone Manual Del Usuario Page 6
May 12, 2017 | Uniden DCT758-4 Phone
Phone says "out of range"
I'd try pulling the battery on the phone that is out of range and letting it sit for a couple of days. Then plug the battery back in and see if the phone activates. If nothing happens then try putting it back in the charger. My guess is if it's been sitting in the charger the whole time, the battery developed a memory and thinks it's dead.
Mar 11, 2009 | Uniden Cordless Phone
How to REregister handsets
You can unregister your phone without being in the cradle, but to re-register them, just put them back in the cradle.  After being unregistered, they will automatically re-register once they are put back in the cradle of the main base.  Try setting them back in the base cradle to re-register, and hopefully that will work for you.
Dec 01, 2007 | Uniden TRU9480 Cordless Telephone
Base handset out of range
Try opening the phone battery compartment on the back of the phone, disconnecting the battery wire, then reconnecting the battery wire. Solved my "Out of Range" problem - phone came back on and worked properly.
Nov 05, 2007 | Uniden DCT758-4 Phone
Uniden TRU9585 Cordless Phone Logo
9,873 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
