Question about Whirlpool GBS307PR Electric Single Oven
Oven locks itself after I put the food in.
Oven locks and I have to turn it off for it to cool off then it unlocks itself.
  • 523 Answers
Sounds like it thinks your putting it in self clean replace control board
Posted on May 27, 2010
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven door is locked with food in it how to unlock asap
    Hi , Anon !
    My name is Ashlynn .
    If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
    Here are some solution on how to unlock the door of your oven ans do self cleaning below.
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
    hope this helps you out please rate this solution it helps get better results for our customers like you
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    The lock will not release after cleaning
    This is GE's trouble shooting advise:
    Range - Oven Door Won't Unlock After Self Clean
    The Oven Door has been Locked Accidentally:
    • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
    • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
    • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
    • Note: Do not force the latch at anytime!
    Door Will Not Unlock After Cleaning:
    On models with mechanical latches:
    • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
    Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
    If the above suggestions do not work try the following to unlock your door:
    1. Disconnect power to range for 30 seconds.
    2. Reconnect power and see if door will unlatch.
    3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
    4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
    5. Wait approximately 30 minutes and try to unlock the door.
    6. If the door unlocks, the control has reset itself and there should not be any other problems.
    7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
    Note: Under no circumstances should you ever force the door or latch open.
    May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
    The oven door won't open, and there is still food in it. We have a Whirlpool Super Capacity 465 Model, amd need assistance immediately.
    Hello. It is possible that the oven accidentally got turned to the self-clean function. Check to see. If it is set to self-clean, the door lock activated. In order to unlock the oven has to be taken off of self-clean and then it has to cool down to room temperature before it will unlock. Joe
    Apr 04, 2010 | Ovens
    Lock would not open after cleaning process has been canceled, oven is still hot
    Don't open or try to open the oven door, until it has cooled down completely. The oven heats to a very hot temperature, usually 800 to 900 degrees. The door locks itself once it gets to a certain temperature, and will not allow the door to be opened until it cools below a certain temperature. On some units, this can take hours to cool down enough to unlock. If you try to force it before the cooldown is complete, it usually results in a repair call. If it still will not unlock when it is cool, turn your power to the oven off for 20 minutes, then turn on and reset your oven controls. Sometimes you have to put the oven back into the self-cleaning cycle, and then cancel it immediately to cycle the oven door lock. If it still won't unlock, call a repair company out to service this. Good Luck, Appliance Specialists
    Jan 19, 2010 | Ovens
    Ge oven turns off by itself, and sometimes gives
    F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
    Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
    · Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
    · Control senses oven temperature above 935 degrees F with the door in the locked mode.
    · Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
    · Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
    · Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
    · Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
    Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
    Frigidaire gallery self cleaning convection oven
    Press and hold the "clean" button for 5 seconds.
    May 11, 2008 | Ovens
    Whirlpool GBS307PR Electric Single Oven Logo
    107 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal DeAngelo
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
