Question about Toro 60'' Com Zero Turn Lawn Mower 27hp Kohler ()
I have a Toro zero turn commercial 60" model 74272 which throws the deck belt as soon as the clutch is engaged. I have replaced every pulley, spacer, spring,etc, as well as a new belt. Also, everything is in line and the belt tension is good. Yet it still throws it off as soon as it is engaged ( at full throttle with no load). Any thoughts?
Im no expert but had a similar problem with an old craftsman mower. the belt keeper which is an L shaped piece of hardware located at the back of the deck next to the idler pulley spindal. Also could be the deck is cockeyed and needs to be leveled or the wrong v-belt.
Posted on Jul 01, 2010
How do I replace an idler pulley on mower deck on toro timecutter mx 5060?
Release belt tension, unbolt the pulley, replace it with a new idler pulley. If you need more help, please follow up here.
Jul 29, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
Replacing deck belt
Make sure that blades are not engaged which will cause the pulley to be out further making the belt too tight for install. There may also be a tensioner pulley that may need to be released.
Jul 24, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Apr 03, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Hit a peice of metal, now mower won't engage.
The mower engages by an electronic clutch. If it doesn't squeal/smoke/start the mower deck when you try to engage the mower, then the electronic clutch is faulty (you may have sent shrapnel into the clutch), or the belt is cut or damaged enough not to drive the deck. If this problem is indeed associated with the mowing metal problem then you need to visually check under the engine - that's where the electronic clutch that drives the mowerdeck is located. You'll notice that there is a drive belt that goes from the engine to the mowerdeck. That's your drive belt. You should loosen the belt and check the mower deck to see if you can rotate the drive pulley and in turn this rotates the blades (of course you do this with the engine off). That would determine if it's the deck or the clutch that has issues. Your instruction manual will show you how to loosen the belt then try to spin the mower deck drive pulley. If it spins by hand then look back toward the clutch. If the deck doesn't rotate then it needs to be removed so you can flip it belly up to see what's hindering the movement. These decks clog easily, but if clogged when you try to engage the mower deck it will squeal. They're easy to remove (if you have some kind of overhead lift - if not they can be a pain). Good luck
Sep 18, 2009 | Garden
Toro 60''  Com Zero Turn Lawn Mower 27hp Kohler () Logo
717 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
