Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washing machine begins and then lights up with error F 50
  • 24 Answers
F50 means that the Rotation Position Sensor doesn't sense any movement from the motor.
If you're tech savvy, repair savvy, you might find this useful : http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Posted on May 26, 2010
What is a error 50 on a GW709NZ fisher and paykel washing machine
Error 50 Hot water inlet valve fault. Control board monitors the circuit through the valve back to the board. If it gets a bad reading it flags that error. Error 49 for the cold valve. It can be caused by a bad valve. Bad wiring connection (corrosion on plug) or fault on the control board. Most times unfortunately it is the control board that is faulty. You need someone to come & test & find which part needs replacing.
Apr 12, 2016 | Fisher and Paykel Washing Machines
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Can't get machine to start a cycle. When press the start/pause button, the door open light begins to flash. After a few seconds, it stops flashing and the start/pause button begins flashing. I have checked...
It is hard to tell if there is no model number. Normally, WP machine has error code appeared on the display. I guess your unit does not have display, so the combination flashing is a signal to tell you what wrong with the system. You can check the service manual normally taps inside the unit.
Oct 22, 2013 | Whirlpool Washing Machines
Fisher & Paykel MW511 error code lights 1 and 7 lighting up and beeping
Error code 130 is rotor position sensor faulty or wiring to it.
sensors sell for $25 to $50 on Ebay.
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
When my Amana washing machine begins to spin the motor shuts off and it will not start for a few minutes also there is a funny smell
The motor is being overloaded, or is old. The funny smell is the motor over heating. Do you get an error code -blinking lights?
Let me know
Jan 09, 2011 | Washing Machines
Program will not start, door light flashing
Has anyone had any joy with this? I have exactly the same problem.
Thanks
May 04, 2010 | Whirlpool AWM8143 Front Load Washer
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
Error lights.
This is a Circuit Board that is bad (main control).Do not repair this because the problem returns,and returns.
May 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Error 54 comes up when you switch it on
all error 50 messages relate to the motor.
Feb 13, 2008 | Zanussi FJS1225W Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
