Question about RCA L42WD22 42 in. LCD Television
RCA L42WD22 42-Inch LCD TV has no sound, good picture
  • 1030 Answers
SOURCE: HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
Posted on Jun 10, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
  • 718 Answers
SOURCE: have a 42 in rca lcd tv ,hsound but no picture
IF the set is under warranty, you should return it.
Do this to see if your set is "sending" the image to the LCD panel.
1) What the set on take a bright flashlight and press it against the screen.
2) Look for the "image" moving around the edge of the flashlight.
3) If you see the "image" then the problem is in the inverter/CCLT or the power to it.
4) If you do not see the "image", you should look at the LCD controller(TCON) for the problem.
Posted on Feb 25, 2009
  • 86 Answers
SOURCE: no signal display on rca 42" lcd
If you have tried other input jacks and cables with the same result, then yes, the input/output board is defective or buggy.  Sometimes a power drain can clear this up as well so it's worth a try:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this doesn't resolve it, service would be necessary.
Posted on Mar 25, 2009
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
HDMI from computer to TV gets sound but no picture??
Check with an other HDMI cable. Sounds like a cable fault. This type of fault is common to HDMI connections.
Dec 05, 2015 | RCA 42la45rq 42-inch 1080p Lcd Tv Black...
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
Sound and rca jacks not working on rca 46 inch lcd tv
check ur set up find manual if no go .go to there web site
Aug 12, 2012 | Televison & Video
Our RCA 32 inch TV L32HD35D has sound but the picture has a pulsating white screen---no picture. We have only had the TV since approximately May 2009. Is there a way to fix the problem? Thank you Susan J....
No,Ur tv under a year old?Still under warrenty?Call RCA for warrenty repair.This problems is a major problems for the tv.The Tuner board it dead,must be replaced it cost u at lest $200 for a refurbish Tuner board.And u have to do the labors ur self.
Apr 25, 2010 | RCA L32HD35D 31.5 in. LCD HDTV
Problem for RCA L32HD35D 31.5 inch HDTV LCD TV I turn it on and no piture just sound
With a bright flashlight see if you can see a picture.. If you can this indicates your invertor board has failed. If not more than likely your main video board has failed. Ebay has tons of parts for these tv's.
Mar 20, 2010 | RCA L32HD35D 31.5 in. LCD HDTV
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Rca 46 inch lcd tv, no sound
Jan 03, 2009 | RCA L37WD12 37 in. LCD HDTV
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L42WD22 42 in. LCD Television Logo
617 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
