Question about Garmin Gpsmap 60cx Handheld Gps
Can't download maps to GPS
A year or so ago I bought a Garmin 60CSX and the TOPO GB maps which loaded to both the PC and GPS. Unfortunately I lost the GPS and have bought another but the maps won't download - I get the message "The following maps have not been unlocked for your GPS" and then lists all 718 maps in the series. Can you help?
Roger
ttech
  • 139 Answers
SOURCE: not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Posted on Jul 24, 2007
  • 3 Answers
SOURCE: How do I get my Garmin GPSMap 60Csx to work with C-map software
make sure your usb ports are turned on in cmos and also make sure that you do not have them set to power saver mode
Posted on Nov 22, 2007
  • 638 Answers
SOURCE: How to Transfer Maps to GPSmap 60csx
Have you highlighted the section with the map select tool, then hit the Transfer to GPS button? If you do, what happens then? Does it freeze?
If you are able to send routes and waypoints to the unit, you should be able to send selected unlocked maps as well.
Posted on Apr 01, 2008
SOURCE: topo map purchase for a magellan gps
forget it
Posted on Jun 02, 2008
SOURCE: connection issues
yeah , i am with garmin 196, and usb to rs232 cable and instaled driver, but it wont connect ..... anybody help ?
Posted on Oct 09, 2008
I have purchased zumo 595lm and have put topo mini sd card loaded with topo maps it has wiped out the origanal maps can i reinstall the origalmaps to it
Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to register it, as well as provide any current updates. Install any maps from this process on the device itself.
Jul 03, 2016 | Garmin zumo 595LM 5" GPS with Built-In...
How to plot my map in this gps
The 60 CSX dosent support custom maps but if you are looking to plan a route or plot waypoints the easiest way is to acquire a copy of Garmins TOPO disks and do all of this on the PC. You can also do this on the unit using " Mark Waypoint".
Hope this helps!
Dec 10, 2010 | Garmin GPSMAP 60CSx GPS Receiver
I cant unlock the map detail garmin topo aus/nz , ive registered and received the 25 digit code but mapsource and basecamp wont recognize it? thanks
Your'e lucky, I can't even get the unlock code. If GPS not reg when unlock started then u can't get email & garmin no help.
Nov 20, 2010 | Garmin GPSMAP 60CSx GPS Receiver
Can't view downloaded sections from Garmin Topo
In Map Setup page, scroll over to blue 'ball' icon (second from right), press lower left button on side of GPS unit, use Thumb switch to scroll down to "Show None", click Thumb switch in. All maps will disappear. Press lower left button on side of GPS unit again, scroll down to "Show Topo.....", click Thumb switch in. Your Topo maps should now show onscreen.
The reason your Topo map might not have shown is because, if you leave the Navigator map showing, and then just press "Show Topo", the layer showing Topo will still be under the Navigator map. This is why I always tell it to show none, and then load whatever map I need to see onto a bare screen.
If this solved your problem, please come back and rate our answer as this assists others. Thank you.
Feb 04, 2010 | Garmin eTrex Legend GPS Receiver
How to use the sd card in a 60csx
Yes. You will load the desired maps onto your SD card, then insert the card int the GPS unit. You then can go to your menu to selt which maps you view.
Dec 14, 2009 | Garmin GPSMAP 60CSx GPS
HOW DO YOU LOAD MAPS TO THE GPS UNIT?
You will need to load the MapSource software on your PC then load the maps into MapSource. After the maps are loaded and unlocked you can plug your GPS into your PC with the USB cable and load the maps.
Hope this Helps.
Jul 24, 2009 | Garmin eTrex Legend GPS Receiver
Unit will not recognize micro sd card with map on it.
your new micro SD card may be too big (in MB). I have the same probem with my camera.
May 31, 2009 | Garmin GPSMAP 60CSx GPS
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
May 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
General confusion with plethora of maps etc
If you have a copy of mapsource read the help file
"Transferring and saving mapsource data"
if the data will not on your (micro)SD card use a bigger one
Dec 25, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin Gpsmap 60cx Handheld Gps Logo
142 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
