Question about Dryers
My atlantis dyer heats, and hums but does not move, could it be the belt?
  • 619 Answers
Yes the belt is broken.
Posted on May 25, 2010
Testimonial: "thanks, that is what we thought"
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
Dyer not working, no heat
fault is from the heating element of your dryer.
Have the heating element replaced and it will be restored.
Regards.
Sep 29, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
When I press the start button on my Kenmore dyer it make a noise but won't start
if it's a humming or like a buzzing noise it's coming from the motor.try spinning the drum by hand,if it moves freely it could be the motor,if the drum is hard to move you could have something like a sock stuck in the blower wheel or something is jamming up the machine and the motor can't move.also just yesterday i found the belt broke and was rapped around the motor so you'll have to get in there and take a look.good luck,let me know what you find
Jun 27, 2010 | Kenmore 63942 Dryer
No heat from dryer maytag atlantis mde7600ayw had heating element them fuse and thermostat checked ok check ciruit breaker turn on and off decided to replace fuse dyer still didn't heat check outlet...
most dryers have a thermal switch or breaker in the cavity somewhere, they can become worn over time and will stop heating, the item probably looks like a copper arm that touches a contact similar to a old morse code key by looks
Sep 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool dyer heat but will not spin
if it is making a humming noise, the belt is either broken or has come off the motor or idler - if it is not humming, the motor might be bad - motor expensive, belt not, but it is quite entailed to replace one if you have never done it
Aug 19, 2009 | Dryers
TRY TO START DYER AND IT JUST HUMS I HAVE A FRIGADARE ELEC FRONT LOADING DYER
The belt may have broken, otherwise you have to use a multimeter to troubleshoot the problem.
Aug 17, 2009 | Frigidaire Dryers
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer quit heating up,timer doesn't work,this happened all at one tim
no dyer run's just does not heat up,timer never move's,which I think need's too for dyer too heat up,i could be wrong,just happened all at one time
Aug 03, 2008 | Dryers
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
