Monitor color problems
My monitor has a blue screen? i tried changing the contrast then it turned pink! What do you think I need to do?
  • 41 Answers
First reset to factory defaults, if it's still abnormal see if the signal cable is seated correctly on both ends (monitor and video card) if that doesn't fix it try with another cable.
Posted on May 26, 2010
Monitor lost color went blue contrast. now well not turn on.
The monitor has at least two issues, the color is lost and gone to blue screen, second it will not turn on. It will be cheaper to replace the monitor with a new one rather than fixing the Star Logic Monitor. But I would suggest using a spare monitor to check the computer for any possible issue.
Jan 08, 2011 | Star Logic 17" LCD Monitor
I get a pop up with a RED CONTRAST screen every few minutes It sometimes goes away if I push the contrast button on my Dell monitor. but it will usually come right back. I have tried everything to stop...
You can try the monitor on another computer to verify it is the monitor and not the display card at fault.
I'm assuming this is an LCD monitor. If you are sure the monitor is the problem, then your monitor's display driver circuit is probably getting close to failing. When one of the three colors (red, green, blue) becomes intermittent, the screen takes on the hue of the working colors. In your case it sounds like the blue is starting to fail.
A repair technician may be able to replace the circuit.
Jul 22, 2010 | Dell Dimension 4700 PC Desktop
My acer Model X221WSD monitor screen is pink. I've tried
Pinkish back ground can be the sign of the lamps are going bad, but usually it will also cause the screen to go into shutdown mode also. Try New VGA cable or move the VGA connectors? Does the same on other PC?
Please post back so we can guide you further toi narrow down the problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 09, 2010 | Acer Monitor Lcd 19in Al1923 0.29mm...
My monitor in blurry and has a pink tinge to it. I can click a button on the side and bring up a box that says brightness, contrast, sharpness,etc- but I can't move off the brightness to change to other...
Use the LEFT and RIGHT arrows (or UP and DOWN arrows)
on your monitor to move between the different items (brightness, contrast, etc.)
However, "pink" is generated when your computer tries to generate "white" (mixing red, blue, green) but one of these 3 "primary" colours is not being generated.
Try your monitor on a different computer, to see if the "pink" is due to your monitor, or due to the video-card on your computer, or due to the data-cable between your monitor and your computers.
Dec 31, 2009 | Addlogix Computers & Internet
Proview monitor PL926WSi Screen goes out after about 5 seconds
Hello Joe,
A red or pink coloration on the screen indicates bad backlight bulbs. They are just like standard fluorescent bulbs just much smaller. When they start failing they light up with a pink color and that will make the screen look pink or red. You can change them but it may not be worth the trouble. You can do a Google search for compact fluorescent tubes and check prices.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Oct 18, 2009 | Computers & Internet
Cannot adjust contrast or color..screen is too dark and tinted pink....
DID YOU TRY TO ADJUST THE SETTING OF your monitor? change the setting of your monitor configuration...
Sep 07, 2009 | Computers & Internet
Too much white color but other colors fine
No no other settings you have to open the monitor one big part called eht will see on that one movable knob will find move it and observe the satisfied picture and stop close monitor
Oct 27, 2008 | Computers & Internet
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
bye:)
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Computers & Internet Logo
177 people viewed this question
David Payne
David Payne
