Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
I have a 55 in Sony Grand Wega LCD TV that has some strange lines that look like cobwebs. They seem to be floating behind screen. What could it be? The TV is 6 years old
    President:
  • 1,099 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CAUTION: immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels.
may be a jumper plug or other means of selecting service mode - not an actual switch.
When moved to the 'service' position, it kills vertical deflection and video to the Tube. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection ports or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection ports on the Tubes.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
My sony wega 3lcd tv seems to have long dust lines inside the tv screen, what is it and do I get rid of it
Dust lines? Please explain. Are they single pixle lines on the screen itself? These are the signs of a failing display.
May 25, 2010 | Sony KDF-E55A20 55 in. LCD Television
The picture and sound on my 55 inch Sony disappears momentarily
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL-2200.You can find it here: http://www.discount-merchant.com/Sony-XL-2200-TV-Bare-Lamp-Bulb-p/sony_xl-2200u_a1601753a_lamp.htm?Click=48173 Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a blue line problem with 50 inch sony wega.
Take to TV repair shop. contact Sony get RMA first for warrenty work! so free work gets done!
Oct 09, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Cobweb?
You'll need to have the frame of the tv either opened so you can reach in there or the top mirror block assy will need to be removed to get inside to the screens. You may want to have a Sony ASC do this type of repair. Call Sony for a referral.
Dec 26, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
428 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
