Question about Arctic Air 22 cu. ft. Commercial Freezer F22CWF
The temp only goes down to 30 farenheit. the thermostat control knob is set to the coldest position. is the thermostat faulty or can it be adjusted?
  • 8,220 Answers
Check list:
Fans running
Compressor cool to the touch
Not short cycling (low freon)
coils cleaned
no air restrictions
If all of that is good bypass the control
see if it gets down to 0
If it does replace the control
Posted on May 25, 2010
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
Refridgarator is not cooling
thermostats are usually a "on/off" switch just as a simple light switch. Ohms on a defrost timer is not very specific. It is basically a switch that turns heaters on and off while keeping the compressor off during the defrost cycle. Your thermostat may be sticking/hanging up.
Jun 04, 2017 | Maytag Freezers
I need to set the thermostat for the freezer on the coldest setting. On what number should place the knob?
On a freezer or fridge usually the highest number is the coldest setting but this may depend on the model of the freezer.
Mar 04, 2011 | Freezers
Frigidaire FRE196A
you know where you adjust the temperature of your fridge. its a knob with a line that increase in thickness. or it may have numbers written on it. before you replace it. try adjusting that knob to set it to a higher temp. please if your taking the covers off the replace thermostat,, please turn the power off first.
Nov 11, 2009 | Frigidaire Freezers
Not cold enough
Should be a thermostat with a black knob in the freezer. Usually they are marked 1-7 1 being the warmest and 7 the coldest. Usually clock wise + colder. Adjust by only 1 number per day. See how it responded the nest day. The set point is designated by a notch or arrow on the cover plate. ;)
Aug 07, 2009 | Freezers
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Purchased a 2004 upright freezer i dont know how to set temp
sir seven is the coldest setting. Good Luck
Jan 10, 2009 | Kenmore Freezers
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Jun 10, 2008 | Kenmore Freezers
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Arctic Air 22 cu. ft. Commercial Freezer F22CWF Logo
371 people viewed this question
Top Arctic Air Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you an Arctic Air Freezer Expert? Answer questions, earn points and help others
