Question about Brother LB6770 PRW Computerized Sewing Machine
Bobbin thread the only thread showing on right side of material
I have a new LB6800 machine that when I try to do the embrodiery, the only thread showing on the right side of the material seems to be mostly bobbin thread. I tried adjusting the tension, but that does not seem to help. As far as I can tell the machine is threaded corrently?
Any suggestions?
Jody Bowyer
SOURCE: thread breaking.
Have you tried to change needle?
Posted on Feb 20, 2008
SOURCE: Adjusting Bobbin Tension
I looked forever to find this darn green bobbin screw. Around the opening for your bobbin is a plastic cover. If you slide it forward it will pop right off. Once you remove this, the bobbin case will lift right out. On the front you will see your green screw for adjusting your bobbin tension.
Posted on Sep 25, 2008
  • 323 Answers
SOURCE: threading lower bobbin
There are some different bobbin cases for different machines but the one you have is a pretty common one with a finger sticking out on top. If you examine the bobbin case you will see a slot on the side of it and there is another piece of metal screwed onto it. This is the tension they are describing.
To thread it properly, turn the bobbincase upside down and insert the bobbin in the case so you can see it. Place your thumb on top of the bobbin and pull the thread through the slot on the side of the case and under the piece of metal(the lower tension) which I described to you earlier.. When you have done that, remove your thumb from the bobbin and pull on the thread. It should have some tension on it.
Next,placing a thumb or finger on the bobbin to keep it from falling out, turn the bobbin case over.
Keeping the finger sticking up lift the lever on the
front of the case and insert the bobbin and bobbin case onto the spindle inside the hook assembly(The part that is in the bottom of the machine that turns when the hand wheel is turned.) Don't worry about the thread that is sticking out.
Holding the upper thread under the presser foot ,turn the handwheel towards you until the top thread pulls the lower thread to the top. Pull the thread to the left of the machine, insert your fabric, lower the presser foot and begin sewing
One more thing , The finger sticking up on the bobbin case will go into a slot on the ring holding the hook inside the machine.
Hope this solves your problem.
Be sure you thread the upper part properly. It should go through the tension, then the take up lever and then the needle. Tension should be set at around 5
sewman7
Posted on Jan 17, 2009
SOURCE: Set the timing
bbragg77 solution lacks a few points that I found out after talking to someone who repairs the machines.
Turn the balance wheel (counter-clockwise) so that the needle moves down and the hook is supposed to be spinning counterclockwise. As the needle reaches the bottom and starts to come back up, stop when the need reaches approximately 2 mm off the bottom. In this position, the point of the hook should be directly behind the needle.
Posted on Jul 25, 2009
  • 55 Answers
SOURCE: Difficulty adjusting tension to avoid bobbin looping
it sounds like your bobbin tension is too tight. to adjust bobbin tension, remove bobbin case (remove needle plate first) and adjust bobbin tension screw on side of case until bobbin thread has a slight resistance as you pull it through the bobbin case.
this will be trial and error until you get best result. you should always try and match top and bottom threads. if the top thread is quite thick you may have continue to increase needle thread tension until balanced.
scott
Posted on Jul 26, 2009
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
The thread on the top side of my material starts looping after 4-5 stitches. I've tried every number of thread tension, and even on 0 it loops on the right side of the material, not on the back.
Check the tension on your bobbin thread. When you hold it by the thread and let it dangle does it just drop down without any resistance at all? If so then you need to tighten it a bit. If the bobbin thread is too loose it can not pull the top thread down enough thus puts the loops on the top side of the stitch.
Feb 25, 2011 | Brother LS2125i Sewing Machine
The thread is not coming out of the bobbin properly
I could not find any reference material for this model.
But, Singer has examples and instructions for both a drop in bobbin and a rotary (side/front) bobbin.
Hope this helps.
If you contact the White Sewing Machine Company they may send you a new manual.
Apr 24, 2010 | White Sewing 1632 Mechanical Sewing...
When I try to use the embrodiery unit the thread bunches up on the underside of the material--it is very loose. Any ideas on what is wrong?
The tension on the bobbin (under the deck) needs to be right. When you load the bobbin, try and pull out the thread a little. It should be firm. You should have to pull a bit to get thread out. If not, the tensioner on the bobbin is set wrong or has backed off (Or you loaded the bobbin wrong) Don't use the bypass slot!
There is one screw on the side of the bobbin holder, where the thread is pulled through when you load the bobbin. This screw can be adjusted to control the tension. See pfaff page on bobbins
Apr 21, 2010 | PfaFF Creative 7570
I have a Singer Futura CE350 and I am trying to embroidery for the first time. I have watched the video and did the tutorial and have it all set up right. My needles keep breaking and my bobbin thread...
Make sure your machine is properly threaded. Use both hands when you thread it. First test your machine sewing regularly, if is fine it could be the tension. It has the tension preset but sometimes it requires for it to be loose or tighter. Also make sure your needles are properly installed. the flat part suppose to be facing away from you.
Are you filling your bobbins in embroidery mode? It helps a lot! Look for the steps online.
Jan 10, 2010 | Singer CE350
Bobbin area will not work
There should be a spinning cover with a hook that fits over the bobbin. Normally, you just pull the bobbin thread out through the swinging/sliding plate hole. Turn the machine by hand toward you (at the top) until the needle dives into and comes back with both threads. Separate the threads and assuming that the thread tension above the needle is set correctly, feed a piece of material in to see if it sews correctly. The tension is set so that the thread is even on both sides of the material. Let the machine pull the material through at it's own pace, your function is to guide the material.
Jul 17, 2009 | White Sewing White 3032
Fabric doesn't Feed
I have a Janome, and when switching from embroidery back to sewing, I must touch a button that electronically moves the mode from embroidery to sewing. In some cases, I've also had to turn off the machine for a few minutes and then turn it on again.
I used to own a Viking - it had a little door covering the attachment link for the embroidery arm. If it wasn't perfectly shut, the machine wouldn't convert to sewing mode, regardless of what button I pushed.
Nov 19, 2006 | Bernina Activa 130
Brother LB6770 PRW Computerized Sewing Machine Logo
32 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
