Question about Vizio P2 42 in. HD-Ready Plasma Television
When i turn on the tv the yellow logo turns white but nothing on screen
    President:
  • 1,099 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} sounds like your vertical circuit was going bad then might have overheated and killed hte power supply, Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement
Good luck :)
Posted on May 25, 2010
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
Sep 22, 2015 | Vizio XVT473SV 47 in. LCD HDTV
How to disable the Startup Logo (White BG with Name)?
It is built into the software and cannot be removed.
Oct 13, 2014 | Computers & Internet
Why is my lg 55le5500 display a white screen
possible mainboard or panel issue. does the white screen ahs any letters or just white with no sound etc ??? when you turn it on does the lg logo appears ??
Jul 26, 2014 | LG Televison & Video
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
Jan 31, 2013 | Televison & Video
BDP5012 Philips bluray dvd player
Hello
You are done the connections right. But look to the socket colours of both the devices, TV & DVD, so match. Yellow, is meant for video, and one among white is for audio. You have to select the input of the tV to [AV], to get the DVD connected to TV. When the input selection comes right, you will see the Logo of the DVD company on the screen of your tV. Some TVs will have AV-1, and AV-2. Try both SV selections. NB: You must power ON the DVD to get its Logo on TV screen. The wire you connected will look like this I assumes.
Feb 27, 2012 | Philips BDP5012 Blu-Ray Player
I plug the white, yellow and red cables from the dvd player into the back of the tv but it says "no signal". I changed the input to Component 1 then I tried the other plugs too but still get the...
Hello
If you have connected the red, white, and yello video cable connection right correct to the respective pins; both at DVD and TV end, by selecting the input to Video-1 or Video-2, you must get the logo of the DVD player on the TV screen. Please not that whether you have 'Power ON' the DVD player. If the connections are good, the logo must be ther. Otherwise check the continuity of the RCA cable, of it may have damaged[shorted]. Try replace with an other cable. OK.
Aug 15, 2011 | Apex Digital LD4088 LCD TV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
My vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Feb 18, 2009 | Vizio L32 32 in. LCD HDTV
Vizio P2 42 in. HD-Ready Plasma Television Logo
121 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
