Question about Sony Playstation 3 (PS3) Console
Wpa number from hub will not connect to ps3 can i change it to a wep number
    President:
  • 1,566 Answers
You can set the authentication or the security settings of your network on your wireless device. You need to consult the manual that came with your wireless router or download one from the internet.
Try to post also additional information next time so that the troubleshooting will be a lot easier.
Posted on May 25, 2010
I forgot my WEP key for my ps3
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Mar 18, 2012 | Linksys Computers & Internet
My son has a PS3 connected through a linksys router (wireless ) in the uk. A couple of days ago his system didnt work and has changed some of the settings..doh I have changed the ssid back to what is...
If the PS3 wont accept your WEP or WPA password it is because it is not the one you chose when you set up the network. The first thing you should do is temporarily disable security on your network and try to connect with your PS3, just to be sure there is not a problem with your network.
If that works, enable either WEP or WPA encryption and choose a new password.
Mar 11, 2011 | Sony Playstation 3 (PS3) Console
Says need to update encryrtion key
It sounds like you changed the password for your router's WEP or WPA security key. You need to go into the Network Settings on your PS3 and set up a new internet connection. Once you do that it will ask you for your new WPA or WEP security key.
Hope this helps.
Jan 05, 2011 | Sony Playstation 3 (PS3) Console
I'm trying to find my wep key or port number, I'm trying to connect my PS3 to the internet.
When you purchased the router, you should have run the "Wireless Networking Setup Wizard" to configure the router, to set an SSID, to set an encryption-level (use 'WPA' not 'WEP'), and to set a password (WPA-key or WEP-key or pass-phrase).
Use those values that you used when you configured your router to configure your PS3.
Sep 12, 2010 | D-Link DIR-615 Wireless Router
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Aug 02, 2010 | Computers & Internet
Im trying to set up my playstaion 3 to play online, it is asking me for a WEP key or a WPA-PSK/WPA2-PSK key and i haven't got one on my home hub.
If you are connecting through a standard ethernet cable you should not be getting this question. However, if you are trying to connect through wifi it is best to check your router/hub to make sure there is no preset factory wep or wpa key
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
Getting a 8013013E connection error code on my ps3
Hello Djwatson99 .
8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
PS3 Trouble due to WEP/WPA-PSK Key trouble
You can always press the reset button and wipe all settings out. You will have to re-enter passwords and encryption to protect your network.
Dec 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
