Question about Ardisam Inc Earthquake Mini Cultivator
Earthquake Viper 43C engines revs up and then quits
  • 1,383 Answers
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
  • 3 more comments
  • scotmcp Mar 21, 2011
    No I have the same problem and I think I understand the question better...though I could be wrong so forgive me if so......This tiller will run for about 5 or 10 minutes when cold, when it gets hot it will rev up and over power.....It can be managed a little bit with the hand throttle, but finally the engine gives up and shuts down and you need to let it cool before it will start again. I was reading somewhere else that the richness needs to be adjusted, but I just read that...this year I actually opted to use my shovel instead of my tiller because this stalling is a real hindrance. Then I started looking around the net today and found some advice I am going to give a try, which is adjusting the fuel richness.
  • Jay Finke
    Jay Finke Mar 21, 2011
    another thing is use marine gas it has no alcohol in it witch eats up the rubber in the carb. just the diagram and a needle fixes it .. about a 10 min job.. oh use never seize on the exhaust bolts , so it can be serviced for years..
  • Jay Finke
    Jay Finke Jun 18, 2011
    IT'S IN MY DNA TO DISASSEMBLE IT, ANALISE AND MODIFY TO PREVENT FUTURE PROBLEMS . MY SAYING IS '' IF I CAN'T FIX IT I'M GOING TO BREAK IT TRY'N '' THANKS AGAIN AND LONG ASHES .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA .. HOME OF THE POOL PUMP REPAIR PUPPY, HE'S THE SIGN OF A BARK'N GOOD DEAL
  • David Hoffman Sr
    David Hoffman Sr Jun 04, 2014
    Jay Finke ... Is this the cause when the fuel runs out of the Air Filter adn floods the engine??
  • Jay Finke
    Jay Finke Jun 04, 2014
    THAT'S THE NEADEL SEAT OR A STUCK FLOAT or on a diaphragm type carb the diaphragm is hard and needs to be replaced, these carb kits are around 10 $. remember to always have extra spark plugs on hand they can be a quick fix for 2 stroke motors. jay
Today tilling with my new viper MC43 tiller, suddenly it just stopped! Unable to restart due to the starter rope, cannot get it to pull out. How do I fix? thanks
it looks like the engine has seized.try turning shaft at bottom of enginei if this is free .engine is ok. remove housing where rope is mounted and free it up....let me know how u get on.....john.
Jul 12, 2014 | Ardisam Inc Earthquake Mini Cultivator
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
CS4518 chainsaw viper engine
Check the compression. It should be 100 psi or above.
Aug 27, 2013 | Earthquake CS4518 - 18" 45cc Consumer Gas...
Problem with a tiller Earthquake viper engine either the carburator or carburator gaskets LBLSNMC43
The Viper Engine is a Honda clone. Try a new carb for $15 0n ebay. http://www.ebay.com/itm/NEW-GX160-5-5HP-HONDA-ADJUSTABLE-CARBURETOR-WITH-FREE-GASKETS/121225345625?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30002%26meid%3Df495007fc18649159ceb1009031e4fad%26pid%3D100011%26rk%3D2%26rkt%3D10%26mehot%3Dpp%26sd%3D261393057447
Mar 04, 2013 | Ardisam Inc Earthquake Mini Cultivator
Earthquake tiller viper 43cc engine will not start
I have the same issue, I thought it was the carburetor so I cleaned it and put it back together, same issue, I put a new carburetor on it same issue, has great spark, if I spray carb cleaner into it, it will start and run for a few seconds even throttle up, but then it dies, and will not start again without carb cleaner spray, and fuel is fresh and properly mixed, very confusing indeed.
Apr 17, 2012 | Ardisam Earthquake Mini Cultivator 43cc...
I have a new Rear Tine Earthquake 6065 electric start 196cc rotor tiller. It runs 5 mins. then stalls and dont start. The first time i thought i was short on clean feul so i filled it. it ran about same...
see if it keeps running with the fuel cap a little bit loose. if so the vent hole in the cap is plugged up and not venting. this causes vacuum in the fuel system and starves the engine of fuel. good luck
May 25, 2017 | Ardisam 5.5 Hp Rear Tine Rototiller
Viper engine on my earthquake tiller starts fine cold then dies after fifteen minutes and wont restart
You probably need a new coil, if it is a 2 stroke then it will almost certainly be the coil. The defect is very typical and recognizable.
Jun 01, 2010 | Ardisam Inc Earthquake Mini Cultivator
Ardisam Inc Earthquake Mini Cultivator Logo
679 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Wade Mobley
Wade Mobley
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
