Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
My web light on my belkin router does not show any connection to web. But my primary computer still connects to internet using router. Why? My other computer show connected, but still can not connect to internet.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Turn everything off, modem, router and computer.
Turn on the modem first and wait for a solid data/connect light.
Turn on the router, give it two minutes.
Still if problem presists you need to reset the router
Posted on Jun 17, 2010
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
Mar 07, 2014 | Belkin N Wireless Modem-Router F5D8633au4A
Emachines wont connect to network
You need to get the model number of the Belkin unit, get on the web and find a driver for that router and install it.
Dec 19, 2012 | eMachines EL1333G03w (884483010820) PC...
I changed my router wep key password code and now I cannot connect to the internet; how do I fix this problem? It does not recognize the connection now and I cannot go back in to change it back to the...
This is how you reset your router.....
Reset the router to factory default With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
How to setup new router:
  • 1 Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • 2 Unplug your router and your cable or DSL modem.
  • 3 Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • 4 Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • 5 Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • 6 Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • 7 Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
  • Read more: How to Set Up a Belkin Router ' eHow.com http://www.ehow.com/how_2292408_set-up-belkin-router.html#ixzz19MK9oA2A
    Dec 27, 2010 | Belkin Computers & Internet
    Belkin Wireless Router F5D8633-4 does not connect to the internet
    Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
    Mar 16, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
    Cannot connect my Mac Pro to the internet via my Belkin wireless
    This will make the router unsecured again, so be sure to go back into setup and reset your Wireless security. I suggest using WEP authentication, and using a 10 digit ph # for your key (that way its easy to remember).
    Dec 31, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
    No internet connection
    I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
    Belkin solution:
    Please follow the details given below:
    1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
    2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
    3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
    4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
    5. Please follow the instructions given below to configure the router manually:
    - Connect the phone line direct to the router, or through the filter.
    - Connect the computer to one of the LAN ports on the router.
    - Switch off the router and power it back after 5 seconds.
    - Restore the router to factory defaults by holding down the reset button on the back of the router.
    - The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
    - The corresponding lights on the router should be lit-up.
    - Check if the computer has an IP address in the range of 192.168.2.x
    - Click on `start` & click `Run`.
    - Type in `cmd` & click `ok`.
    - Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
    - If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
    Then follow the below instructions to reset IE.
    -Open Internet Explorer
    -Click on Tools -> Internet Options
    -In the General tab, click on Delete Files under Temporary Internet Files
    -Click on Clear History
    -In the Connections tab, select Never Dial A Connection and click on LAN settings
    -Uncheck all the options and click on OK
    -In the Advanced tab, click on Restore Defaults
    -Click on Apply and then OK.
    - Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
    - You should be able to access the routers set up page.
    - By default the password is blank.
    - Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
    - Save the Changes.
    Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
    Internet Status should show Connected on the top right hand corner of the web page.
    If the problem persists, please get back to us with the following information given below:
    1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
    2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
    3. ADSL broadband connection or Cable broadband connection.
    4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
    5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
    Log on to the router web interface at http://192.168.2.1
    - By default, the password is blank.
    - Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
    6. Then, check the IP address of the computer. For checking the IP address:
    - Click on start & click `Run`.
    - Type in cmd & click `ok`.
    - Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
    - The IP address should be in the range of 192.168.2.x (x=2 to 254)
    - In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
    - Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
    - Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
    Dec 28, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
    Internet connection
    i don;t realy understand ...
    so u have a wireless router and the computer that connects to it shows that is connected but it doesn't work on the internet ?
    than the computer connecting to the router is connected, but the router it self is not connected to the internet ! Go at the router settings and configure the internet connection ...
    if this is not the issue, please try to explain again with more details what the problem is....
    Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
    Set up my belkin g router
    You may have to configure the belkin router depending on the type of ISP that you have.
    Basically, you can do these to configure your router:
    1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
    2. turn off the modem, router and the computer for 30 seconds
    3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
    Installation CD
    I lost my installation CD and received these instructions from the Belkin Tech Support, and was able to install the Wireless N Router with no problems.
    Follow the steps given below for configuring the Belkin N router manually.
    - Connect the computer to the "LAN" port on the router and connect the modem to the Internet/"WAN" port, using Ethernet cables.
    - Take a paper clip, insert the paper clip in the reset hole of the router and hold it for 15 seconds.
    - The power light will flash and then come back "ON" solid, indicating that the router is being restored to factory defaults.
    - The corresponding lights on the front of the router should be lit up.
    - On the computer, check if you have an IP address in the range of 192.168.2.x.
    - If not, specify a static IP address, gateway and "DNS" address by following the steps given in the link-
    - Log on to the router web interface by typing in http://192.168.2.1, in the address bar of your browser.
    - Click on "Connection Type" in the left hand column under "Internet WAN" heading.
    If the connection type is Dynamic (cable):
    - Choose "Dynamic" and then click on "Next".
    - Type in your “Host Name”, if you’re Internet Service Provider has provided it. Else, leave it blank.
    - Click on "Change WAN MAC Address".
    - Click on the button "Clone".
    - Click on "Apply Changes".
    If the connection type is PPPOE (DSL):
    - Choose "PPPOE" and click on "Next".
    - Enter the user name and password given by your Internet Service Provider.
    - Save the settings.
    - Click on the "Home" link at the top of the screen.
    Internet Status should show "Connected" on the top right hand corner of the web page.
    If the problem persists, please get back to us with the following information:
    1. Type of connection provided by your ISP (Is it PPPOE, Dynamic or static).
    2. Name of the Internet service provider (ISP).
    Aug 11, 2008 | Belkin Wireless-N Wireless Router with...
    Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
    218 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
