Question about Dishwashers
Cuisina Dishwasher Integrated Cuisina dishwasher dw-007 giving E4 code. Thanks.
  • mattjgilbert Sep 02, 2008
    Getting same E4 on Cuisina DW00. Not been cleaning correctly for a while and now making continuous beeping noise and nasty motor noises. Seems to also have been responsible for tripping the power twice in the last 24 hours.
SOURCE: E4 error on new conia dishwasher
Had the same problem. First you will need to tilt dishwasher back 45 degrees and tip out all excess water. A couple of towels on the floor are a good idea.
Second check that the little nozzle on the elbow under your sink where your overflow attaches is drilled out.
This fixed my problem after fussing around for a day and I was starting to disconnect everything to take it back.
Posted on Dec 22, 2007
SOURCE: I HAVE A KENWOOD KDW12ST3A
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Posted on Oct 29, 2008
SOURCE: Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
Posted on Nov 15, 2008
SOURCE: powerpoint dishwasher E4 error code
The solution below applies to a Powerpoint dishwasher but is probably a generic one for E4 problems - given that brandnames are frequently badges of convenience for made-in-china products.
The problems cause and solution goes as follows:
Problem:
Any water that leaks (for whatever reason) from the internals of the machine finds it's way down to the lowest point of the machine - down under the washzone and into the area where all the workings of the machine are located. There's a sensor there (a polystyrene float operated switch in fact) that detects this water - causing the machine to empty and go into error 4 (E4).
The solution will depend on the nature of the leak. If it's due to one of the various seals on the floor of the washer leaking or there is some problem with water level controls then that will have to be repaired first - otherwise you'll keep on getting the error. In my case however, the "leak" was actually a design feature of the machine and is easily rectified.
Open the dishwasher door fully and look at the floor of the machine where it meets the bottom of the door. You'll see a couple of plastic tubes protruding from the floor by about 12mm - one to the left and one to the right. Their function appears to be to act as an overflow if the water level in the machine gets too high (for whatever reason). This excess water is directed down these tubes and into the bottom of the machine where it can be detected - rather than letting it spill out onto your expensive floor. The weakness in this system is that it only takes a soup spoon of water to produce the error - something which might accidently happen during the course of a normal wash.
Options:
1) Leave the machine idle for a few days until the water evaporates. The sensor switch will reset and the error will be gone when you switch on.
For either of the following solutions, turn off the power to the machine by unplugging it or tripping the relevant switch at your fuse board
The stainless steel washcabinet is only slightly thicker than aluminium kitchen foil. Handle the machine gently and never force it otherwise you're in danger of distorting the cabinet.
2) Tilt the machine right the way forward so that the water leaves the area of the sensor. It'll flow back again once you level the machine but in wetting the floor area of the machine, the level at the sensor will be a little lower than before - permitting the sensor to reset. Switch on and the problem should be gone.
3) Pull the machine out from the built in unit to gain access to the right hand panel. Remove it (just a lot of philips screws holding it on) and you can just about see the polystyrene float (near the front) and the slightly depressed area underneath it - in which the water accumulates. You can poke a stick in with some tissue taped to it to mop up the water. Be careful not to disturb or damage the float.
note:
I've had this problem occur twice in as many years. If it keeps on occurring then you likely have a genuine problem with water level controls during filling or a leaking internal seal dripping water into the bottom of the machine.
Don't be tempted to block the overflow tubes - a genuine overflow could destroy your kitchen!
Posted on Feb 21, 2009
SOURCE: how to reset error code e4 on delonghi dishwasher
Remove all dish trays from washer, unscrew and remove lid off salt softner, tip machine on side untill all water drains from the salt softner, replace all trays and softner lid and machine should work again.
Posted on Apr 18, 2010
How to get into bottom section of dishwasher to find a leak
i had the e4 code today. fixed it, thank god.
Sep 09, 2016 | Dishwashers
DISHWASHER- Model no: DW009
Hi i know you give the model number but what make is it i will find out what the fault code is for you then i can advise you on the best way of solving the problem tell me your make and model number and ill try my best to help you ok speak soon
Nov 29, 2007 | Dishwashers
Why am I getting an error code iCO on my frigidaire gallery dishwasher?
I just addressed a iCO error code on my 2 week old Frigidaire Gallery DW. I reset the circuit breaker as recommended online and it worked fine for another few days and then came back. Customer service cannot tell me what the error code means. They WILL NOT replace the DW, rather want to schedule a service appointment. I have no desire to repair a new DW so I am receiving a refund from the retailer I purchased from. On to the next brand!
Aug 18, 2014 | Frigidaire Gallery FGHD2465NF Fully...
I have a gorenje gv60010 dishwasher. it has a flashing e4 fault code which does not let the dishwasher operate. can anyone tell me how to reset it
Well your all brilliant. Point 1. The filer in the bottom of the machine was full of Cra* once I cleaned out the filter, pulled the integrated machine away from the wall and (Point 2) tilted it on its back legs (you were right about the mess - as more water came out) the E4 signal went. Im just trying it now so will come back if the machine doesnt work!! Thanks for the advice!
Mar 06, 2011 | Dishwashers
DW won't start
ck the door inter lock / they hace a new improved one . if its hard to release handle its probably bad . very common .. mm
Dec 07, 2009 | Electrolux EWDW6505GS Fully Integrated...
Baumatic bdw45 Dishwasher
REMOVE MAINS POWER COMPLETELY, then remove the plastic covers from base of machine and sponge out the bottom catch tray
Sep 17, 2008 | Baumatic 18 in. BDW45.1 Built-in...
E4 code on dishwasher
Hi
Sorry, I still don't know what the problem is. I've been washing up by hand! Looks like I will have to call an engineer out at some point .... I'd better save some money :-)
Janine
Sep 02, 2008 | Dishwashers
I HAVE A KENWOOD KDW12ST3A DISHWASHER AND IT HAS THE E4 ERROR CODE THEY DID NOT GIVE ME A MANUAL WITH IT CAN YOU HELP
Apr 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
DEC Dishwasher
I have a manual if you still would like a copy
Apr 04, 2008 | Dishwashers
Dishwashers Logo
137 people viewed this question
Top Dishwashers Experts
