Question about Ovens
I have a H350-2B miele oven. What is the difference between auto roast and surround when roasting vegetables?
    Brigadier General:
  • 3,917 Answers
Hi
Roasted vegetables make the ideal accompaniment to that Sunday joint. These can simply be slid into the oven above the meat to cook. ... In a Miele oven they can be baked using either Fan Plus function or the Automatic programs.
SURROUND is a mode which does not utilize the convection fan but instead heats from the bottom and top of the oven. Use SURROUND ROAST when preparing meats that benefit from a long slow cook time, such as pot roast or brisket. SURROUND BAKE works well for meringues, soufflés and any delicate baked good that would not benefit from the blowing of the fan.
And for cooking roasts and whole birds, AUTO ROAST works well. It is a convection program which automatically sears meat at 450 degrees F for about 15 minutes and then drops down to a default temperature of 325 degrees or any temperature you select to finish cooking with Convection heat. By inserting the roast probe into the meat and setting it to an appropriate internal temperature (you can look in a dependable cookbook for these temperatures), the oven will beep and shut off when the roast is done.
Foods that usually take a long time to cook are finished in a much shorter time when using AUTO ROAST. For example, a 19-pound unstuffed turkey will take about 2 1/2 hours to cook on AUTO ROAST as compared to about 4 hours in a conventional oven.
Auto Roast heats the oven to a high temperature to sear the meat, retaining moisture and tenderness...The oven temperature then automatically returns to the preselected setting...... Casserole dish, combo rack with glass tray, earthen cookware...The cookware must have heat-resistant handles...... In this function cooking times and delay start times can be programmed..
In Surround roast, the function allows you to brown meat and poultry..
Please check this official miele oven site,which will be a good help for you..
http://www.miele.co.uk/experience/Recipes.aspx
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Posted on May 25, 2010
How to defrost a roast lamb in a vario stream oven
Have a read of this. I am a chef and would advise the traditional way.
Cooking a Frozen Roast Without Thawing - Cooking - eGullet Forums
https://forums.egullet.org/topic/112634-cooking-a-frozen-roast-without-thawing/
Feb 5, 2008 - 25 posts - ‎15 authors
So now there's a 10 or 11 lb. beef shoulder in the oven. ..... roasts with additional water added as required were put into a large steam kettle to ... This works with any meat Pork, Lamb, Beef or even Frozen Turkeys especially at ...
defrost roast lamb in vario stream oven Google Search
Apr 30, 2017 | Ovens
Beef tri tip roast in oven
Directions
  1. Rub roast all over with thyme, basil, marjoram, mustard, salt, and black pepper. Place meat in a sealable plastic bag, seal the bag, and refrigerate, 8 hours to overnight. ...
  2. Preheat oven to 450 degrees F (230 degrees C). ...
  3. Place meat in the prepared roasting pan.
  4. Roast in the preheated oven for 15 minutes.
Tri Tip Roast Recipe - Allrecipes.com
allrecipes.com/recipe/240779/tri-tip-roast/ Beef tri tip roast in oven Google Search
Dec 21, 2016 | Ovens
How to oven roast pork shoulder roast and at what temperature
There are hundreds of internet recipes for pork shoulder (or porkbutt--which is just a couple pieces of pork shoulder that are butted together and tied with string).
roast pork shoulder Google Search
Apr 17, 2016 | Ovens
How long to I roast
What are you roasting and what temperature?
Nov 28, 2015 | Ovens
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    Cannot get vegetables & potatoes to roast & crisp up properly
    Use fanbake and crank the heat up to 250 Par boiling the veges will help
    May 18, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
    Ovens Logo
    326 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
