Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
When I first turn on the tv I get a degraded
When I first turn on the tv (42" toshiba hp83 plasma) I get a degraded picture from the cable and the dvd. After a few minutes the picture turns to normal and remains that way until the next time I boot it up. Is this a circuit board problem and an easy fix?
Hi did you ever solve this problem? i have the exact same issue, i think its the main-y pcb but want to be sure. green pixels, slow refresh rate on screen, after 5mins the picture is normal till next time i turn it on.
Posted on Jun 19, 2010
42 plasma tv didnt dispay picture by l canhear some sound
If you are using HDMI output could be a bad or cheap cable.
I had same problem, tried another HDMI cable and all OK.
Jul 06, 2012 | LG 42LC2D 42 in. LCD HDTV
Tv off automatically
The condition of your TV called power supply overcurrent shutdown. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating .I would probably also check the flyback circuit and flyback transformer although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
DON'T FORGET TO RATE:
Oct 10, 2008 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
42" Toshiba Plasma TV no picture or sound
My experience with 42" plasma tv's with no picture or sound was a missing power supply voltage. On the power supply board check voltages on the plug. The voltages should be marked on the board,
Mar 01, 2008 | Toshiba 42WP27 42 in. Plasma Television
X and Y Sustain Boards
How is the picture displayed? Distorted or dim?
Dec 03, 2007 | Philips BDS 4611 46 in. Plasma Television
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
When watching dvd having showing or fade background
yes it can be down to signal degradation especially via scart lead, make sure you use a decent scart if you buy an expensive one you can tell the difference. Run a cable from your sky digibox direct to your tv to see if the picture improves.
Oct 05, 2007 | LG 42PX4DR 42 in. Plasma TV
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
212 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
