Question about Photography
Damaged Manfrotto 410 junior geared tripod head
any help would be appreciated. I dropped my tripod with 410 junior geared head, and the aluminium lever which locks and unlocks the camera from the plate broke. Does anyone know if it's possible to get hold of spare parts for the head.
Cheers, David Speight.
  • 685 Answers
Try www.BogenTripodParts.com for that part. It is not listed on their site, but they can most likely get it.
Posted on Jun 25, 2010
Manfrotto 804RC2 Tripod head
Hi Shirley
-When you look at the center column you should see a small plastic 'nub' about 1/2" from the bottom.
-When raising the column in preparation to move to the horizontal position this must be depressed or it will not 'pass through' the top casting.
-Once this has occurred the column can be raised enough that it will then freely drop into the horizontal position.
Jul 05, 2013 | Manfrotto Photography
Is there a Carbon fibre small compact with splitter
Carolyn
-If you are looking for a compact light weight (CF) tripod for video...., that is going to be...., stable & durable (for use with a smaller video camera or a DSLR) & with a mid-level spreader...., I have some bad news for you. They do not exist!!!!!
-You can get a number of tripods that meet some of these requirements..., but not all!!!
-No fear....., it is still possible to get a tripod that is small, light, repairable and with a higher weight capacity and better durability than either of the Manfrotto tripods you mentioned..., but they will not use a mid-level spreader!!!
-Questions for you...., the manfrotto #055CXB has a column that terminates with a flat plate & a 3/8-16" thread. The Manfrotto # MTV502AM tripod has a 75mm bowl mount. Do you use a video head with a flat base or with a 'bowl'?
-If your head has a flat base consider looking at CF tripods from brands such as Sirui (#N2204 or #N3204)..., great value tripod from China..., or products from Gitzo or Really Right Stuff...., (superior products...., and your grandkids will be using them..., but pricey)!!!!
-If your head uses a 75mm bowl mount get the Miller #1501 tripod...., stupidly strong and well supported.
-Bottom line..., with light to mid weight cameras, if you go with a good quality spreaderless tripod that uses 'rotary locks' vs 'quick release' locks...., the leg mechanisms are so superior that you will find that you will get less flex than most tripods with spreaders. They will also be smaller, lighter and allow you to shoot far closer to the ground!!!
Go t a shop that has a good selection of quality tripods and test for leg twist..., you will be converted!!! (note: to test this leg flex..., extend the legs & grab hold of (2) of the tubes near the top 'crown' and then try to move the legs to the left then right...., many will exibit significant flex at the joints!!!!
Jun 21, 2013 | Manfrotto Photography
I can't get the ball head off my tripod. I've loosened the set screws at the base, but the head won't budge.
You can try this:
spray lubricant between ball head and base, wrap the ball head with a heavy rag( to help prevent scratches, use a pip wrench on ball head while someone else holds legs ( or also wrap legs in cloth and hold in vise). DO THIS AT OWN RISK
Dec 04, 2010 | Manfrotto (Distributed by Bogen) 055XB...
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 | Cameras
The spring on the release arm not working/broken Manfrotto 410
that is not a repair that the user can make. Contact the service department at: manfrottodistribution.com
Mar 17, 2010 | Photography
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Manfrotto 322rc2 tripod ball head
here is manfrotto's "How To" site, they have illustrated how to use almost all of their products.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/offonce/pid/2475
hope this helps out. if you have other questions please lemme know
Nov 04, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Jul 02, 2007 | Bogen Communication Bogen - Manfrotto...
Photography Logo
284 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
