Question about Samsung X820 Cellular Phone
Bluetooth how to activate my bluetooth ear piece to my mobile
  • 1 more comment
  • Anonymous Apr 27, 2008
    my bluetooth won't activate....
  • Anonymous Jun 18, 2008
    failed bluetooth error
  • raydev Jan 29, 2009
    does not connect with my phone
Hi I just bought a Samsung E250 ,all the Samsung phones are a little difficult to pair with a blue tooth earpiece,first you must get your earpiece to emit it's code on my earpiece the little light will flicker from green to red all the time it is doing this,on the Samsung phone you must make sure that the phone is set up go to Bluetooth and then Activation make sure it is on,it's a weird system double check its on,then go to Devices its down from Activation and set it to search for Bluetooth device ,if your earpiece is emmitting it's signal the phone will pick it up and ask for the code of the earpeice most are set at 0000 enter your code quickly and then set the device into the phone ,then it'sjob done. Samsung are good phones they pack alot of stuff into them and are cheap but the most annoying thing about the E250 is getting the back off took mine to phone shop he did it in seconds hold the phone upside down with the Samsung logo facing you in the palm of your hand then with the other hand press down on the join on the back of the phone and slide towards you.
Best of luck Brian.
Posted on Jan 22, 2009
What do i have to do to fix this bluetooth problem? it works before why suddenly it just won't activate
Posted on Apr 27, 2008
SOURCE:
Can't connect to the mobile
The phone has a feature on the setting area allowing for user to enble or disable wireless connectivity. Usually, access the phones menu area to acquire the settings buttons from where to locate the bluetooth button also called wireless capacitor. Turning the wireless button on the phone to ENABLED makes possible acquisition of any available signals. Also, the blue tooth ear piece may have a power button. pressing on the display button on ear piece while wireless capacitors are enbled on the phone should be capture user impressions. keep in mind that the phone may be functioning with wireless however requires for a phone call to be received to ascertain that the bleu tooth was audible. Make someone call your phone once blutooth is installed to ascertain that the connection was sucessful.
Jan 22, 2011 | Jwin JBTH200 Hands-Free Bluetooth Ear Clip...
Tip
How to get your ge ear piece to connect
How do I link my GE Bluetooth in ear style headset, model 86707 or 86710?
Answer :
Turn on the mobile phone and place within 10 ft of the headset.
With the headset turned off, press and hold the Talk button for about 7 seconds. You will hear a "pair" tone and the LEDs will flash continually to indicate the headset has entered into pairing mode.
Release the Talk button. The headset is now is "pairing" mode.
Initiate the device discovery feature (Bluetooth discovery) on the mobile phone. Refer to your mobile phone manual for further instructions.
When prompted by the phone, enter the headset passkey (0000). When pairing is complete the LEDs on headset will flash at 3 second intervals and the headset will be placed in standby mode, ready to make and receive calls.
Note: On some mobile phones you will need to activate the Bluetooth feature first and then search for the Bluetooth device. Please contact your cell phone manufacturer or the User's Manual for further information on how to pair pair Bluetooth devices.
Click to view the instruction manual for:
86707
86710
on Feb 28, 2008 | GE Bluetooth In-ear Headset Wireless...
I need pass code to activate my wep450 ear piece
The passcode for this and it never changes is 0000 you would input this into your handset for pairing, let me know if you still have trouble, Thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 03, 2010 | Samsung WEP450 Bluetooth Headset - Retail...
Lost My pin for the bluetooth AOEM GW-BT-002 headset. the generic 0000 pin does not work and neighter does the 8888
Hi johan56s The pin is 1234. Hope this helps ???
My problem is,that i can make a call using my ear piece,but not sure on how to receive a call via ear piece.If i just answear via Mobile, can only hear through phone.Wish i didn't mislay my handbooks. Hope someone can help. Cheers Waveslider123
May 24, 2010 | Motorola Cell Phones
Sony ericsson mobile
not really sure what your problem is ,
but if it is on how to pair a bluetooth ear piece to the phone this will vary slightly depending on the ear piece you are trying to pair.
May 19, 2009 | Jabra Sony Ericsson W300 / w300i / W550i /...
Accidently deleted ear piece and now my storm cant find the device? The bluetooth icon shows up on my screen and when i activate the ear piece it keeps asking me for passkey which i put in 0000 but it...
Do you still have your charger cradle? Try putting in the number that's bolded on the bottom of the case. Mine is a twelve digit number and it is the pin number that your phone is looking for. At least it was for mine.
Feb 24, 2009 | Motorola Mobility H680 - Headset -...
Cannot connect to my ear piece
have you gone through the pairing process? Also make sure your old phone is turned off when you pair the new one.
If you need pairing instructions, a video on H710 headset might help you - it should be pretty similar. The video is on www.HandBookLive.com under Electronics category (Motorola Bluetooth headset H710).
Jan 13, 2009 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Bluetooth repair
i have a blue tooth motorola h350 and it just quit working it's under a year old can you get me the 800 number so i can get it replaced
Dec 10, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Plantronics ear piece
i need a passcode for my bluetooth so i can put it on my blackjack
Dec 06, 2007 | Plantronics Explorer 320 Headset
Samsung X820 Cellular Phone Logo
206 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
