Question about Refrigerators
Hi! My name is Sue. I have got a professional fridge in restaurant. I just need to know, where I can buy spare rubber seal between a door. Could you give me advice? please. I am from London.
  • 4,102 Answers
Hi could you please tell me make and model please as i am also in the uk birmingham te be exact, i need to know the make and model of the unit then i can locate the parts for you and give you any links.
Speak soon ok
Posted on Apr 08, 2008
SOURCE:
My fridge/freezer is frosting cos the rubbers shot x local repairman says he will not fix as "it never works"x can I replace them myself? difficult? x leroy
most places have a " seal-a fridge " type business that comes to your place and makes and fits door seals to fridges and freezers
check in the trade pages of the phone directory or go google and type in--- fridge door seals and repairs -- to see if there is a business close to you
the only problem that you may have is , if the door and seal edge area is badly rusted
if you can get a seal from a service agent spares and you have some ability you may be able to fit the new seal your self
Nov 22, 2016 | Refrigerators
The rubber seal has been damaged (ripped) can I replace the door seal?
yes you can,if you google "candy fridge spares"you will find lots of suppliers.
Oct 16, 2010 | Candy CPL321K Refrigerator
Leak in rear lifthatch water leaking into rear storage area. It appears to be getting in under the rubber gasket door seal
Hi this is quite a common problem, you have a couple of options you can either go out and buy a new door rubber seal or if it one of those seals where you can get you hand in between two parts of the seal then what you can do is get some thick string and run this in the middle of the seal doing this will pack the seal out a bit and then when the door is shut this will make a lot better seal and it will then stop the water getting in.
let me know if you need further assistance ok
ps the rubber seal isnt to expensive to buy but even a new rubber may still have the same problem as its more to do with the way the door is fitted and it seems it dont push the seal hard enough to prevent water getting in so i have found packing it out with some thick string or twine will push the seal out more and will seal it properly when you shut the door to
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 31, 2010 | 2007 Chevrolet Equinox LS New Cars
I have a sears 50188 3ton floor jack that is leaking. Do they make a seal kit?
Hi, they dont make seal kits for jacks but one thing you can do is if you take the seal out it will either be a rubber o ring type or copper ring type take this out then go to a car spares shop and buy the same type of o ring doing this will solve your problem, most parts in these you can buy off the shelf so take the seal out and go to a car spares shop or hardware store and ask them to match one up for you, make sure its the exact same size etc and you should find this will stop the leak and fix your problem.
Aug 23, 2010 | Home Fencing
Hi my Asko fridge has a freezer compartment - I
not sure why the seal is faulty but yes you can buy a rubber seal for the door go to your local hardware store you might have to look in the section that stops drafts from entering a room or rubber flex material with a adhesive tape that can be formed into any shape eg around a outlet pipe or to seal a window etc and you can always trim some rubber sealer to fit if its a little large . I used a foam roll with adhesive tape to seal my freezer door on a mini bar fridge and its still in use today
Oct 26, 2017 | Refrigerators
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Aug 16, 2009 | Whirlpool Refrigerators
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | GE Refrigerators
What is the cost and where to buy rubber seal for Bos
Need the model number to find the related costs.
Try this website link; just enter the model number and you can get the spares you need and order them.good luck.
click here and enter the model number
Apr 11, 2009 | Refrigerators
Toyota matrix 2004 body door opening seal damaged
use silicone to rebuild it
or
go to auto salvage yard & buy a used one
Jul 05, 2008 | 2004 Toyota Matrix
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
