Question about 3Com 3C16985B /REF3COM SSII 24-PORT SWITCH (3C16985BREF)
Problem related to switch ports
Iam having a 48 port switch . out of 48 some ports are not working ? can i know why
  • 298 Answers
It is possible that the ports are busted already.
Posted on May 08, 2008
SOURCE:
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
We have a Linksys SRW2048 48-Port Gigabit Ethernet Switch. The problem is, that we can't get a connection on the 8 ports on the very right side. What could be the problem, how can we solve it?
Disconnect all the Ethernet cables from all the ports.
Connect one of those eight "bad" ports to your laptop.
See if the port works when it is the ONLY active port.
If not, move the cable to the next of the eight "bad" ports, and test again. Repeat.
Move the cable to one of the 40 "good" ports, and test.
If it works, then you have a hardware problem with that "group" of 8 ports.
Your choice to use only the 40 "good" ports, or to replace the router, if you need those last 8 ports.
Jul 11, 2011 | Linksys SRW2048 48-Port Gigabit Ethernet...
Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
Fsm750s 48 port - we had ports 9,10,11,12 go out in a storm - can they be repaired? power on/off didn't reset - going into the Netgear via IP and disabling and enabling also did not work
Unfortunately, nothing to be done other than replace it if you need the ports. You could in theory replace the chip or chips that got burned up but it would probably not be worth it and it it's an ASIC(likely) you'll probably not even be able to source it.
Sep 10, 2009 | NetGear FSM750S Ethernet Switch 48 x...
The purpose of hp procure switch 2626
There is nothing special about these switches other than that they are managed. Managed means they have some means of connecting to them and "managing" them like you do when you configure a wireless router by going to some ip address in your browser to access the configuration. They usually are able to communicate statistics, set up virtual subnetworks, monitor ports, mirror ports, control which ports can access which others, set speed limits on ports, etc... A normal switch is "dumb", there is nothing to configure and it just does it's thing, connecting anybody and everybody that are connected to any of it's ports. Procurve switches are popular because they are great switches, there are other managed ones that can be had for much less, I use 48 port managed Linksys that have/exceed these capabilities for way cheaper... examples
Jan 28, 2009 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Performance Issue
thats not a big diffrence if you use a 24 port switch or if you use 48 port switch actually switch is used to a number of connection not for a internet speed that is use for a networking if you want to upgrade your configuration then you upgrade your ram and our hard dives configuration
Dec 19, 2008 | Dell PowerConnect 2224 (0M4575)
Switch 2950 24 ports with problems
yellow light on ports means the port is not working or was shutdown due to port security
Nov 20, 2008 | Cisco Catalyst 2950 24x10/100 Mbps...
Computers & Internet Logo
103 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
