Question about Goodman CKL60AR60 Air Conditioner
What should be the correct supply and discharge temperature of a goodman hvac
    Guru:
  • 415 Answers
Depending on the temperature & humidity level in your house, the temperature difference of the air entering your air handler and the air blown into your house should be in the 16 - 21 degF range. The temperature difference of the air entering your condensing unit and the air leaving your condensing unit should be between 25 - 30 degrees, with 30 degrees being for older model units. Anything above 30 requires cleaning.
Posted on May 25, 2010
What problems can occur when you overcharge the hvac
The level of overcharge will dictate the severity of the possible problems. The most common problem with overcharging is creating high compressor head pressure which over-amps the compressor motor which waste energy and shortens compressor life. Installed high pressure safeties will usually shut off the unit off and must be manually reset. High system pressure also results in higher evaporator temperatures and higher air discharge temperatures. Grossly overcharged systems could return liquid to the compressor, destroying it.
Sep 04, 2014 | Heating & Cooling
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Hvac superheat verses subcooling
superheat is the difference of line temperture at suction of the compressor to the pressure converted to temperture for freon used in system. subcooling is the difference of temperture measured on liquid line compared to pressure measured at discharge line converted to temperture for the freon used in system.
Sep 06, 2012 | Goodman Heating & Cooling
2.5 ton goodman coming on but the fan isnt blowing air throught the ducts smoke
>check for the content of refrigerant from the accu-chiller maybe the refrigerant pipe has a leak that is why the condensation of the basic refrigeration cycle does not takes place so in return high temperature is producing on the fan coil unit to which the air duct to supply fresh air to the room is discharging a smoke instead of a fresh air.
>check if the accu-chiller has an air restriction from its condenser fins because if it has an air restrictions the hot air from this unit cycling around cannot discharge to the atmosphere that is why the FCU to which the airducto to supply fresh air is connected will be producing a smoke.
>check for the FCU fan motor overloading to which the airduct to supply fresh air was connected that is why it is producing a smoke.
Jun 18, 2011 | Goodman Heating & Cooling
Central air unit out side will run non stop in hi temp cond and not cool very well, coils have been cleaned along with condenser and evap. it will run and turn off in early morning hours, freion is wher it...
Here is what you need to do to make sure your system is charged correctly go to the furnace take the temperature of to supply temp and take the return temperature at the furnace. You should have 18-20 degrees temperature difference if your return temp. is 77 degrees you should have 57 to 59 degrees. If you dont have these temps your system either wasnt cleaned properly or not charged correctly. If this helps please rate me and do a testimonial.
Jun 07, 2011 | Goodman Heating & Cooling
I have a 1999 Chevy Malibu and the AC turns from inside air output to outside output on it's own. You can push the inside air button and it will go back and then in a second or two it will go back to the...
Yes , the Refrigerant level is good , I would say the control panel is bad , or there is a problem with HVAC Air Delivery/Temperature Control Circuit Description
The vacuum actuators move the air valves in the HVAC system (except the temperature valve). Vacuum is applied to the actuators through the mode selector in the heater A/C control assembly. The mode selector consists of a rotary vacuum switch. The rotary vacuum switch supplies vacuum to the vacuum actuators according to the operating mode selected by the driver. A small servo motor moves the air temperature actuator. The small servo motor positions the door according to the voltage level from the temperature selector in the heater A/C control assembly. The temperature selector is a potentiometer positioned by the temperature control knob on the front of the heater A/C control assembly.
Air Temperature Actuator
When the ignition switch is in the RUN position, battery voltage is applied to the air temperature actuator. The actuator receives ground at all times through the following components:
• CKT 251
• Ground G204
The temperature selector is a potentiometer with a wiper arm. The wiper arm is electrically tied to the air temperature input through CKT 733.
When the temperature selector is moved between COLD and HOT, voltage to the control input varies between 1 and 12 volts. The temperature valve motor solid state circuitry performs the following tasks:
• Looks at the control input voltage
• Moves the motor to correspond to the control input voltage
The temperature valve moves for the following reasons:
• In order to allow the air to pass through the heater core
• In order to allow the air to pass around the heater core
This control achieves the desired passenger compartment temperature.
HVAC Air Delivery System Check
Step
Action
Yes
No
Start the engine.
Turn the blower motor fan ON and select an air outlet mode.
Does air flow out of the selected HVAC outlet ducts?
Go to Step 3
Go to Step 2
Did the customer concern mention that the air discharges out the correct ducts at first, but then changes during higher engine RPM?
Go to Step 7
Go to Step 3
With the engine running, cycle the HVAC controls through all the modes.
Does the air come out of the selected outlet ducts?
Go to Step 18
Go to Step 4
With the engine running, take a vacuum reading at the manifold vacuum port that supplies vacuum to the HVAC vacuum control assembly.
Is there engine vacuum?
Go to Step 6
Go to Step 5
5
Repair the no vacuum condition.
Is the repair complete?
Go to Step 18
6
Take a vacuum reading at the vacuum supply line at the HVAC vacuum control assembly.
Is the vacuum reading the same as the engine vacuum?
Go to Step 11
Go to Step 8
7
Disconnect the vacuum supply line from the HVAC vacuum control assembly.
With the vacuum gauge connected to the vacuum supply line, re-start the engine and turn the engine OFF.
Does the system lose vacuum after turning OFF the engine?
Go to Step 8
Go to Step 11
8
Inspect for leaking or collapsed vacuum lines between the engine manifold vacuum port and the HVAC vacuum control assembly.
Are the vacuum lines leaking?
Go to Step 9
Go to Step 10
9
Repair or replace the collapsed or leaking vacuum line.
Go to Step 18
10
Replace the vacuum reservoir tank.
Go to Step 18
11
Using an external vacuum source, apply vacuum to the appropriate vacuum line at the connector to the HVAC vacuum control assembly.
Does the actuator retract?
Go to Step 17
Go to Step 12
12
Inspect for leaking or collapsed vacuum lines between the actuator and the connector to the HVAC vacuum control assembly.
Go to Step 9
Go to Step 13
13
Disconnect the vacuum line from the actuator.
Apply an external vacuum source to the actuator.
Did the actuator retract?
Go to Step 14
Go to Step 16
14
With the actuator disconnected, inspect the door for binding.
Does the door move freely?
Go to Step 16
Go to Step 15
15
Repair the appropriate binding door.
Go to Step 18
16
Replace the appropriate vacuum actuator.
Go to Step 18
17
Replace the HVAC vacuum control assembly.
Go to Step 18
18
Cycle the HVAC controls through all modes to verify proper operation.
Did you correct the condition?
System OK
Apr 05, 2017 | 1999 Chevrolet Malibu
Unit not cooling
Low on refrigerant charge! Low side line should be cold like a beer can at the inlet of the compressor with some sweat beads around it. 55deg. The discharge should be around 125deg just hot enough you cant hold it long!
Jul 26, 2010 | Goodman CKL60AR60 Air Conditioner
Schrader valve extremely slight leak
No I don't think it will. They make a tool however that will allow you to change the schrader valve core without losing any charge. You can get them at HVAC supply stores. ($30+)
May 26, 2010 | Goodman CKL42AR42 Air Conditioner
Need circuit board for Goodman GMNP-060-3 Rev B Furnace
Go to your nearest HVAC supply house. They should be able to get you it.
Apr 04, 2009 | Goodman GMS90703BXA Heater
Noisy compressor at start and end of defrost cycle
overcharged temperature split times cfm gives you btu's did he check static pressure .50 or less
Feb 19, 2009 | Goodman Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
118 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
