Question about Mitsubishi WS-55807 TV
How did you resolve the power supply problem on the Mitsubishi TV model WS 55807? I just obtained one and my guess was a power supply. Where can I obtain one, would you know? I much would appreceiate any response. Thank you for your time. Mark D'Andrea in Anaheim (714) 323-3363 [email protected]
  • 927 Answers
Good Day, ana4;
Look for fluid on the PCB's, if can't find any, try this:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH. how did you resolve the power supply problem on th - back.gif
Posted on Aug 07, 2008
SOURCE:
My TV will not turn on, it was working fine one day then the next day there is no power
Sounds like a power supply issue in the tv. The regulator and a fuse are probably at fault. I had one today of the same model with the same problem. There is a small solder in fuse, a soldered in regulator ic and a capacitor that needed to be changed. A reasonable repair cost for this repair would be 155-225 us dollars depending on if in-home service is needed. This is only my best guess . Hope this helps. Good luck, Russmann.
Apr 29, 2011 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
Mitsubishi 55807 power up ,green light, then turns off.
http://www.opweb.de/model.php?id=2693 is a free link to download service and user manual-- i have the same issue with my tv
Jan 23, 2009 | Mitsubishi WS-55807 TV
Ws-55807 convergence
I had the same issue for months and finally had to have a tech come by and fixed it - $400.00 later.
Aug 13, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
WON'T STAY ON
That is a typical problem in the power supply. It could be a switching regulator that has i think 7 pins, but it gets the power supply up and running with around 157VDC. If that is missing the set won't power up at all. Where are you located. I'm in Louisville Kentucky. Let me know if that works for you. Keep in mind there are quite a few fuses in there too. so check those. I think on that model there is 7 or 9 fuses to check. Talk to you soon. Jay
Jan 14, 2008 | Mitsubishi WS-55807 TV
WS-55807 doesn't power on
1) Check all fuse devices in power supply
2)Pc board with transformer possibly defective.............T.
Nov 07, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55807 tv
call a repair man not much else  you can do, try and unplug for a few min
Oct 17, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
473 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
