Question about Maytag MSD2454G Side by Side Refrigerator
I have a maytag refridge model MSD2433HE. It is leaking from the under part of the icemaker and causeing water to drip down to the shelfs forming ice cycles. Ofcourse this is causeing it to freeze so I have had to unplug. I have taken the front part of ice maker off and see where nothing should be leaking. Also if you use the front water or ice part water will start to come out around outlit to ice dispenser. Help! Also how do you take the pan out or do you? It has water in it I just cannot figure how to get to it. Looked at front and didn't see a way and I have looked at the back and didn't see a way.
smilemaker
  • 790 Answers
SOURCE: Ice Maker Issues
HELLO!!!
THIS MAY HELP U ...
http://www.applianceaid.com/icemaker.html#overflowing
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Posted on Jan 02, 2008
aborcass
  • 2651 Answers
SOURCE: Bottom of freezer has water dripping into it
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 04, 2008
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
Ice maker is leaking water at the rear of the ice maker, somewhere around the water inlet. Water is dripping slowly and building up an ice ***** BEHIND (outside) the ice cube storage bin AND inside the...
Hello,The reason all the ice freezes together and you see icecicles forming from the icemaker,is going to caused by the water inlet valve on the back of the refrig.is not fully closing but instead it's seeping water through it and dripping into the ice storage bucket. To stop that from happening the water inlet valve would need to be replaced.
On refrigerators that have a built in water filter,alot of times their will be 2 water valves and the one that is bad causing water to seep through it will be the one called the SECONDARY valve.
GENE
Sep 30, 2011 | Maytag MSD2454G Side by Side Refrigerator
I have a Kenmore Model 60192000, freezer on top and no ice maker. Have a leak on left side over top shelf. It is coming from apart in the refrigerator above the shelf, has kind of a square neck. I do I...
Is it a leak or a drip? A leak means you have continuous running water and a drip is more inconsistant.
I would suspect that you have a drip, that is caused by your cooling tube having frost or ice buildup in it, which is quite common for some units. The fix that seems to work the best is to defrost your unit, making sure the cooling tube is completely free of ice and frost by blowing hot air from a hair dryer down it. Then cutting a piece of bare electrical (solid core) wire that will fit down the tube but not extend past the opening. Then you form a hook and put it around your defrost heater.
That way the heat from the defrost heater will be transferred down the wire and keep the tube free of ice and frost.
Jul 28, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Water leaking underneath icemaker, dripping into ice tray
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the first one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 20, 2009 | Amana DRS2462B Side by Side Refrigerator
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD2454G Side by Side Refrigerator Logo
216 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
