Question about Canon PowerShot G5 Digital Camera
My canon powershot G5 won't turn on even after i charged a new battery and put it in. Does anyone know what's wrong with it?
t00nz
  • 4738 Answers
SOURCE: Problems with the battery and the flash on my canon powershot A530
Know this is an old post but... Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mentioned that your batteries weren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on Dec 16, 2007
SOURCE: it wont turn on
Try to check if your charger in the first place can still charge your battery. It could be the reason why there is no "charging light" indicator.
Posted on Mar 10, 2008
Hello
First, you must be certain that your battery pack is still good.
You have to clean all connecting point (between the camera and the batterry) with a dry clean cloth inside the battery pack compartment.
Another think to check, is the date and time battery (dime size battery located inside the battery pack compartment) to remove it, slide the battery case out and change it. Since the battery is install at the factory, it verry possible that there is no more power. At the end of your owner manual, you will find, before troubleshooting section, the way to remove it, it verry easy, no force need it.
A deffective flash card can also cause the problem. Remove also the flash card and replace it by a new one or another one that you have.
When the battery is fully charge, install it along whith the new time and date battery. Leave the camera alone for a couple of hour in order to let the board get some refresment. Try to put it on, if it not work, slide in and out the battery, couple of time, close the compartment and try again.
In many cases, the camera will start and you will have to put the time and date, if the battery (time and date) was warn out. Make sure that your screen is on. You ready to go. :)
Posted on Aug 16, 2009
SOURCE: Canon Powershot SX110is: problem with the batteries
Make sure you are using Lithium batteries. Alkaline batteries will go dead immediately in this camera. I've tried it.
Posted on Nov 10, 2009
SOURCE: Canon Powershot A470 - asks to 'change battery'
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
Posted on Jan 21, 2010
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot SD1000 Digital Camera
Canon Powershot A470 - asks to 'change battery' every time it is turned on, then turns off immediately. This is so even when new, fully charged batteries (different brands, rechargeable, non-rechargeable)...
Jan 08, 2010 | Canon PowerShot A470 Digital Camera
Canon Powershot G5 won't power on, even with adapter
If you can open it and you have experience and skills in fixing electronics, you can try in repair it.
Check the fuses on the printed board circuits.
They are labeled with a P, H or K in the middle of them.
Check them for zero ohms to test them with a meter,.
If you prefer not to do it, then it needs to be professionally serviced, which may be expensive (at least more than buy an used one).
Regards,
Regards,
Aug 06, 2008 | Canon PowerShot G5 Digital Camera
It won't turn on
There could be something going on the battery contacts. Your camera may still be under warranty. I would check it out with Canon
Jun 22, 2008 | Canon PowerShot A560 Digital Camera
It wont turn on
Hello
Feb 15, 2008 | Canon PowerShot G5 Digital Camera
Canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
Dec 16, 2007 | Canon PowerShot G5 Digital Camera
Canon G5 Lens error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 07, 2007 | Canon PowerShot G5 Digital Camera
Canon PowerShot G5 Digital Camera Logo
241 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
