Question about Craftsman 4 Cycle Blower/Vac
Craftsman Leaf blower Model 358.797290 plastic fuel pickup hose is broken. Which hose goes to the primer button and which to the gas tank on the carb? Is the inner diameter the same on both hoses? Do both hoses go all the way to the bottom of the gas tank?
5 Suggested Answers
  • 6 Answers
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
It sound like the primer bulb does not retract by itself due to aging problem.
Posted on Jun 18, 2009
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
mickey813
  • 472 Answers
SOURCE: need manual for craftsman blower/vac model 358
if you googel searsparts open that link then put in your model number and look for the link that says need a manual for this clik on it and you can get it hope this helps you
Posted on Nov 07, 2009
#1 Taper
  • 1040 Answers
SOURCE: Craftsman leaf blower Model # 358794761
Sounds like you have dirt in carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Leaf blower not pulling fuel into carbeurator
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to replace carburetor.
Dec 31, 2011 | Craftsman Garden
Fuel hose to the gas tank has broken as well as the primer hose has broken
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Aug 03, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
I received an answer for a 25cc gas trimmer, however, my problem was with a Craftsman 32cc Gas Blower. I need to know where all the three gas lines go??
The routing of the fuel lines is the same. If you have 3 lines, that means the primer bulb is not directly mounted to the carb, rather it is connected to the carb with hoses.
Line 1. Comes from the fuel filter in the tank (smaller diameter hose) directly to the inlet port on the carb. This is the port that is opposite the diaphragm on the carb. Diaphragm is held on with 2 or 4 screws through a chrome plate. Make sure to leave enough hose so the fuel filter will fall to the lowest point of the tank when it is being used.
Line 2. Goes from the other port on the carb to the short side of the primer assembly.
Line 3. Goes from the longer port of the primer assembly and returns to the tank. Sometimes this line will have a simple coupler on the inside of the tank, but it is optional and its only function is to keep the line from slipping out. If yours does not have this coupler, just leave an inch or two of line in the tank.
*If both ports on the primer are the same length, you can test to see which is pushing air out...that's where line 3 goes.
Oct 15, 2010 | Craftsman Garden
No gas when you prime it
1) Check fuel lines from tank for cracks, fuel filter in tank, primer bulb for cracks
2)Remove Carburetor
replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 13, 2009 | Craftsman Garden
I am replacing the fuel tank assy and purge bulb (i.e. primer) on my Sears Craftsman model 358.798940. The original plastic tubing was old and brittle and broke apart while disassembling, so I could not...
The order of fuel travel should be:
Fuel filter to fuel hose to Carb's Fuel Supply nipple. (On the main body of the carb)
Primer Plate Nipple on carb to fuel hose to Suction Nipple on Primer Bulb. (It must pull fuel thru the carb, not push)
Pressure Nipple on Primer Bulb to fuel hose to Fuel Tank Return hose.
When correctly installed, the fuel will be PRESSED into the fuel tank via the return hose when primer is pressed in . . . and SUCTIONED out of the tank and into the Carburetor when primer in released.
Hope this helps,
Dolf-
Oct 16, 2009 | Garden
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Craftsman leaf blower, primer bulb will not return, won't start
Apr 22, 2009 | Craftsman Garden
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
Craftsman 4 Cycle Blower/Vac Logo
376 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
