Question about M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System
Gaps and noises in my Session recording
When I play back my recording in M-audio Session USB Fast track there are small gaps in the sound as well as crackling and other strange noises. I have been through the M audio trouble shooting and knowledge base and have had no success.
I'm running windows XP pro SP3
Is it bus powered? If it is only plugged into the USB port and not also into the AC outlet, it may be because your USB port does not supply enough voltage or enough current. USB is spec'd at 5V, 500mA, but many fall short. I have the same problem with a Tascam US-122. I haven't tested yet, because it doesnt have an external power port. I would need to splice 5V power into the USB cable.
Posted on Jun 10, 2010
There is a 1 second delay from the time i play to
adjust your audio buffers, if your recording software allows it. however, there will always be some latency in usb recording devices. i recommend firewire or pci internal cards for recording.
Nov 30, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
JVC XL-R2010 CD Recorder - recording dao problem
Reading the manual over and over, it looks like there is a function called Autotrack and by default is ON.
In the manual, page 22, shows you how to put the Autrack OFF.
Be careful that if you use the synchronize one-button recording you will have again the Autrack automatically ON again and that means a pause or bump between tracks.
For your reference I used the manual at this location http://resources.jvc.com/Resources/00/00/98/A0013ien.pdf
Please let me know if you need further help.
Oct 28, 2007 | JVC XL-R2010 CD Recorder
How do i stop tha tracks from skipping, because while im recording tha audio tracks seem to skip
Depending on whether you are using recording software and what kind you are using you are experiencing what is known as latency. It happens when your computer is not fast enough to keep up with what you are recording. More RAM sometimes helps. Sometimes it is just a simple adjustment. It is too long a subject to go into here. Try looking at Audacity which is freeware. There is a good explanation on their site. Also, I would recommend Asio4all. Hope this helps.
Oct 21, 2009 | M-Audio Producer USB Microphone with...
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
M-audio fast track sound only coming out of right side
I havent played with acid a lot... but this is what i can tell you... most of the softwares have configurable inputs... seems like your inputs are configured as stereo input and hence it will pick up the signal from both the left and right discreetly... which means that you would need to feed audio to both the channels for the meter to pump on both bars...The other option is to PAN the track center and not hard left right... this would get audio to both ears of headphone as well as the output meters...
these are basically some of the few things tht will get u sound on both ears and bars...
The bigger question here thoug is why do you want to record in stereo?? and not mono?
Jun 29, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
I have a Tascam DP-02(not 01) and need to seperate songs
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Apr 10, 2009 | Tascam DP01 All-In-One Recording Package...
No sound recognized in Audacity from Fast Track M-Audio
First thing is what operating system is on the computer.
Second is what does device manager say about the recording interface?
Third in audio properties from the task bar icon, what is the default device for recording?
Feb 23, 2018 | M-Audio Fast Track USB (FASTTRACK) Audio...
Sound in one ear only
The Fastrack only has one audio input signal to the PC. You'll need to set your recording software to mono, then you can add stereo fx in your audio software.
Jun 06, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Drum track
From your description it sounds like you recorded the midi drum patterns to a track first and then playback from that track is giving you problems. If this is the case it sounds a lot like a bug that existed in the firmware prior to release 1.02 where edits could cause gaps on tracks. You can check your firmware version on bootup and if you don't have version 1.02 installed you can get the firware and instrustion on how to upgrade it here:
http://www.tascam.com/details;8,16,5,19.html
Feb 13, 2008 | Tascam 2488 Portastudio Multitrack...
Open Questions:
M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System Logo
139 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
