Question about Panasonic SC-HT730 System
Does not play dvds suddenly, problem just started
The unit itself works but does not read any dvds in any slot
    President:
  • 1,099 Answers
the problem can be solve by opening the cover of the player. use a dry cotton bud to clean the lens and observe the red light beam on the lens when the player is power on. check for the ribbon cable, because if the ribbon cable is bad , the lens will not beam up a red light. if otherwise replace the lens to the same type.
hope this help
Posted on May 26, 2010
Hello, I have a CyberHome 300 dvd player. The unit was brand new and playing dvds perfectly. I decided to go through some older VCDs (mostly 2.0) that I had and it played the first one fine for a...
U could have damage the laser eye data reader,because u tries old VCDs with a different version of device data informations disc.Tries device unplug,replug the device back like an hour later for the thing for resetting itself back to the factory setting.Device it might be work probally again,if still the same problems.It is a new unit wright?Take it back where u bought it for a replacement unit.
Mar 14, 2011 | Televison & Video
Player connected dvd does not play looks like it is reading disk
First, try a different DVD. If this activity is present for all your DVDs then the laser either has a dirty lens or the laser LED itself is starting to fail.
If you know how to do it, you can try increasing the bias on the LED, but chances are that will only help for a while, and the laser will eventually burn out completely.
It's time to start looking for a replacement unit, unless cleaning the laser lens fixes the problem.
If the unit reads other DVDs then obviously the DVD itself is defective and not the player.
Feb 24, 2011 | Goldstar GBV241 DVD Player/VCR
I am unable to play dvds. The system starts with
Try other discs to see if the system is reading anything.
If it isn't then take a can of air and blow some into the drive to make sure there is no dust or dirt on the laser.
After that, try again and if the system isn't reading discs still then that means that the laser is bad. You can either replace the laser or the dvd drive itself.
Dec 01, 2009 | Sony Playstation 3 (PS3) Console
After playing a cd in unit will no longer read DVDs
Had the same symptom. The unit would play CDs but not DVDs. The DVD laser was at fault. Purchased and replaced laser unit KHM-313AHC (ebay- $20) and it now works fine.
Jul 16, 2009 | Disney D7500PDD Portable DVD Player
Sony NEC OptiArc can't read but can write!!!
Try to play the cd that you have wrote with other machine if it was able to read with other machine then your dvd is faulty.
If it cannot play with other machine, then there is a problem with the software that you use in cd writing or the dvd rom drive. Try to re-install both drivers, then play a cds.
Jun 03, 2009 | Dell Computers & Internet
DVDs only scan and won't play on LG LHT754
There may be some dirt blocking the lens of the laser. They make cleaning kits, which you can get at just about any electronics retailer. If that doesn't work, you might have a defective unit.
Mar 18, 2008 | Audio Players & Recorders
Doesn't read dvd's
This problem is down to failure of the laser and an only be solved by replacing it. Samsung are aware of this fault but will only offer a free replacement if the unit is still covered by it's warranty.
They do offer a replacement service but charge £94 for it.
Jan 31, 2008 | Samsung DVD-HR734 DVD/HDD Recorder
Not reading dvds or cds
press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE until innitiliazing appears try several times
Dec 25, 2007 | Panasonic DVD-RV32 DVD Player
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Panasonic SC-HT730 System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
