Question about Texas Instruments BA-II Plus Calculator
How do i get the correct answer to this problem using the this calculator, log 4 3
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Assuming you mean the log-base-3 of 4,
press 4 LN / 3 LN =
Posted on Feb 22, 2011
Not getting right answer when I enter natural log (1/37+4)..
1.393 is the correct answer for the natural log of (1/37 + 4). I believe you want natural log(1/37) + 4, which is .3891 .
Watch those parenthesis. By putting the "+4" inside, you're doing the addition before calculating the log. You want to calculate the log and then add 4.
Nov 27, 2012 | Texas Instruments TI 30XIIS Scientific...
I have a Casio fx-82au plus and want to input logs to the base less than 10. Is there a way to do this? eg log to the base of 2 = 16 (answer is 4 but how do we get that to work on this calculator).
You can calculate the logarithm to any base by using the relationship
logb(x) = log(x)/log(b) = ln(x)/ln(b).
To calculate the log base 2 of 16, either divide the log of 16 by the log of 2 or the ln of 16 by the ln of 2.
Apr 07, 2011 | Casio FX-115ES Scientific Calculator
How do you find the logarythm of log 4^1/64
I believe you will have to calculate part of this then input the rest of it. So one way to do this would be
to press [1/x] [6] [4] get an answer of .015625. Clear the calculator then press [4] [y^x] then put in the previous answer .015625 then [log] . This should give you .009407.
Mar 07, 2011 | Texas Instruments TI-30XA Calculator
When I substract log(2) from log(4) I get .301029957, the answer should be 2, what is wrong?
The answer for the problem log(4) - log(2) is actually 0.301, so the good news is that your calculator is working properly! Here's a quick breakdown of the solution for the problem:
1) We know that log(x) = N means that 10^N = x. So in this case, we need to find a number that 10 can be raised to in order to get 4 and 2.
2) To get a better idea of what the answer to the problem will be, we look at the scale of the numbers. 4 and 2 are both smaller than 10. In order to raise any number to a power and get a smaller number, that power must be less than 1. If the power was 1 or greater, the answer would be more than 10. Therefore, we know that log(4) is a decimal less than 1 and log(2) is a decimal less than 1.
3) Now we'll simplify the problem. A logarithm rule states that:
log(x) - log(y) = log(x/y)
We can use this rule to simplify the equation in the problem.
log(4) - log(2) = log(4/2)
Since 4/2 = 2,
log(4) - log(2) = log(4/2) = log(2)
4) Now to solve the equation, the only thing that must be calculated is log(2). This would be done on a calculator. In step 2, we analyzed that log(2) must be less than 1. Therefore, the calculator is correct with the answer 0.301.
Hope this helped!
Nov 30, 2010 | Texas Instruments TI-84 Plus Calculator
DB to Power ratio using antilog
The conversion formula is
# dB =10*log(Pout/Pin) for say an amplifier.
For your case
Pout/Pin= 10^4 then #dB =10*log(10^4)=10*4=40 dB
Let us take a less obscure exemple
# dB= 57.39, what is the power ratio?
10*log(Pout/Pin)= 57.39
log(Pout/Pin)=57.39/10=5.739
Pout/Pin=Ratio =10^(5.739)= 548276.9649, not a number you would hear or see quoted, but a correct value.
To calculate the power ratio
  1. Convert the decibels in Bels (divide by 10)
  2. While the number just calculated is still in Answer memory (ANS), press [SHIFT] [LOG] to access the the 10^x function
  3. Press [SHIFT][(-)] to enter (ANS)
  4. Close the parenthesis [)]
  5. Press [ENTER]
Here is the screen capture for the calculation one way and back.
Mar 02, 2010 | Sharp EL-531VB Calculator
Hoe do you use logarithm on TI-36X SOLAR?
Basically you first have to put your answer into scientific notation by pressing the 3rd key then the 6 key. The screen display should change to one big zero and two small zeros.
I was workinggon the same problem with a -log of a chemistry problem to get pH and I knew the answer because I calculated it on it TI-85, but we are not allowed to use graphing calulators on the exam (:-((() so I had to figure out how to do it on this one!
For example, I had pH =-log(2.828947x10^4)
On the TI-36X you change to scientific notation using the instructions above. Once the three zeros enter on the screen:
[4]
[2nd]
[10^x]
1^-04 should appear on screen, then you multiply by 2.828947
[x]
[2][.][828947]
then your screen will show the answer in scientific notation.
2.828947 in big numbers and in small numbers -04
From there you simply press:
[log]
and your answer will show up as a negative number. Just take the absolute value of that and you have your answer. Took me like 30 minutes the night before a huge chemistry exam to figure that out! Hope it helps someone!
May 09, 2009 | Texas Instruments TI-36 X Solar Calculator
How do i use the inverse log operation on the TI-84
The problem is simple. You're trying to get an [H+] concentration which is obviously going to have a value of some number times ten raised to a negative power. Therefore, you have to insert the negative value of the pH into the 10^(x). When you insert said negative number you will come out with the right answer.
i.e.
The pH of a sample of human blood was calculated to be 7.41. What is the [H+] concentration of the blood?
10^(-7.41) = [H+]
[H+] = 3.9 E-8
(the answer should only have two sig. figs because the pH has two digits after the decimal.
Jun 10, 2008 | Texas Instruments TI-84 Plus Calculator
How to calculate log value in calculator with different base value
In any scientific calculator log2(n) can be  calculated with either ln or log function as follows
Log2(n)= ln(n) / ln(2)
Or
Log2(n)=log(n) / log(2)
both will give nearly the same answers
Dec 08, 2007 | Casio FX-300MS Calculator
Texas Instruments BA-II Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
