Question about Hayward H-series Electronic Gas Pool Heater H300
Hayward H300 Pool Heater shuts off after about 2-3min
Hayward H300 shuts off after running about 3-5 minutes each morning. Will not run again until night usually. Sometimes (not often though) it will start up again for a few minutes if I click the igniter button, but it turns off again after a few minutes. Strangely enough it seems to run fine the last 3 evenings after dark, but will not work at all during the day, probably coincidence? Heater is about 7-yrs old, heat exchange inside is new. Gas pressure is fine (verified by gas company), filter is clean (new sand and backwashed).
5 Suggested Answers
john224
  • 1378 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
Posted on Jun 12, 2009
  • 4 Answers
see this link ....
http://www.fixya.com/support/t1078177-hayward_pool_heater_h_series
Posted on May 25, 2009
  • 139 Answers
SOURCE: pool heater won't light
it is possible to light a pool heater with an ignition device,however it is not advisable.since your unit is calling for heat and the gas valve is opening,i suspect you have a faulty ignitor
Posted on Jul 24, 2009
jharwell668
  • 640 Answers
SOURCE: pool heater will not ignite
Try the owners manual for these pool heaters. It will have suggestions for getting your problem corrected.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
Low appears on the digitial display
may be a faulty pressure switch. the code LO represents not enough water flow for the unit to run. check for blocked lines. remove the supply\return lines to heater and make sure the shipping caps were removed (seen that happen)
page 38 of your owners manual
Jun 01, 2014 | Hayward H-series Electronic Gas Pool...
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
Cant change pool heater temperature
see if set on remote if not bad display board or hold up and down at same time for 7 seconds maybe locked
May 21, 2013 | Hayward Pool & Spa
Where is the temp sensor on a Hayward H300 ED2 pool heater
take off top there is a copper wired unit going into header and wire to the board
Sep 18, 2012 | Hayward H-series Electronic Gas Pool...
Hayward H 300 series pool heater for an inground pool. Pilot light is lit. Filter is clean. If I jump the terminals the heater will go on. If not the heater will not start.
I have an H300 Millivolt Hayward heater. It will start and run for about 1 minute then shuts off along with the pilot going out. I've tried cleaning all the terminals and running all new wiring but same result. I've also jumped out the TH to TH terminals leaving the jumper in place and it still shuts down after 1 minute. Any idea what that could be ?
Apr 24, 2011 | Hayward H-series Electronic Gas Pool...
Hayward H300 heater runs but will not heat water
Your internal by-pass could be stuck open or the disc could be worn to the point of letting water pass too fast. Or your thermal control valve could be stuck open. These are both found in your water header going into the heater. Hope this helps, good luck.
Jul 02, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
Where is the pilote on hayward h300 pool heater
Follow the aluminum tube from the side of the gas valve down and it will lead you to the pilot assembly.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Mar 05, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H300 Logo
238 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
