Question about Black & Decker 5700 Powershot Forward Action Stapler
[email protected] CHAIN SAW DN301H5
I know this is an old saw but is in very good order but the main drive gear
has striped some nylon teeth (this is the gear with the metal gear chain drive)
  •  Bobby
    Bobby May 11, 2010
    What exactly do you need help with. If you could provide a detailed description of what you need help with, we should be able to help you. Thanks
I have the same problem. The combined nylon gear and chain sprocket is now obsolete and no longer supplied by Black and Decker so it is down to stockists who may still have this part available. I have tried all the official spares stockists without success so any suggestions?
Posted on Oct 13, 2008
Go to the shop and buy a drive gear
Posted on Jul 02, 2008
SOURCE:
Have a problem with my electrical Kraftsman chain saw, the engine is running and the chain is rotating, but when I put it against the tree for cut, the chain will stop rotate bot the engine is still...
The main drive gear is slipping. This is caused by etiher worn teeth or worn bearings. If you pass the model number I can show you a diagram of where to look and what part or parts that have most likely failed. The drive gear is the weakest link but the motor can be shifting in the housing away from the drive gear. It only takes a bit less than 1/8 inch side play. The model number will be similar to this 358.341160
Most likely it is item 26 of this diagram:
http://c.searspartsdirect.com/lis_png/PLDM/P0101241-00001.png
This example is for model 358.381160
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358341160/0247/1503210/P0101241/00001?blt=06&prst=&shdMod=
Thanks for choosing FixYa, Kelly
Sep 13, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
Chain has a rattling noise but has lots of oil.
I would start by closely inspecting the chain bar. Make sure it is not warped,bent,or twisted even slightly.Look for any dents or burrs in guide channel and make sure gear teeth on the end are in good shape. Slight burrs can be filed smooth with small flat file and minor dents canbe straightened with needle nose pliers then touched up with a file.If you find any problems other then minor replace the bar.
Check chain over carefully making sure that all drive tangs are in good shape,not bent,chipped,or exccessivily worn.
Most importantly make sure your chain is properly tensioned. The way I do it is once I've made sure the chain and bar are in good shape I tighten the chain snugly with saw at operating temperature. Check to make sure chain rotates freely and restart saw and run at high R.P.M.s for 30-45 seconds. Shut off saw and wearing gloves grip chain at mid point of bar and lift saw. I try to get enough clearance to slip a nickle between bottom of drive tang and top of bar. tighten bar retaining nuts and run saw for several mins. and check again. Hope this helps you and thanks.
Dec 21, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I HAVE A POULAN PRO 260 42cc 18 inch THAT IS 5 yrs old REPLACED BAR AN CHAIN . WENT TO CUT SOME TREE LIMBS CAN NOT EVEN MAKE ONE FULL CUT AN CHAIN COMES OFF AFTER 4 TIMES WENT AN RENTED ONE.
Remove the new chain and compare it against the old one. Do the new drive teeth match the 'pitch' of the old chain? If incorrect, the chain cannot be adjusted properly and will 'climb' over the sprocket due to the chain teeth not matching the teeth on the drive sprocket. Getting the proper chain is the answer in this case. Hope this helps!
May 02, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
My saw runs well when the chain and bar is off but will not turn the chain when it is on the bar. What do I need to do?
1) insure that the 'chain brake' is diactivated
2) inspect the drive teeth on the sprocket for being worn (appears as a groove in the center of the teeth)
let me know from there, rwvanlue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Remington chain saw, electric: jammed and now the
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "M30016US" into the "Model #:" window, then clicked search.
  • Click the M30016US - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" think you want item 18, 113004-01, Internal Gear
  • Click the 113004-01 - USE REPLACEMENT PART # 122513-01 "View Part" link.
Results follow:
Part #: 122513-01 Price: $24.00
Description: KIT, INTERNAL GEAR (MOD) 747 B/O
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Nov 10, 2009 | Remington M30016US 16" 3.0 Peak Hp Modular...
I need to find the nylon gear that is fused to the steel gear that drives the chain 1625 elec.poulan chainsaw. part name, number and picture.
An IPL for a Poulan 1625 (type 1) can be found here:
http://www.ordertree.com/modelinfo/PWE/1625-Electric-Saw-Type-1/75.1625-Electric-Saw-Type-1.1.59.1.html
Click the green "Go" tab; Expand the "Illustrated Parts Lists";Click the "Chain Saw Assembly Type 1".
I think you want item 7 ($10.32 & shipping). The nut probably has a left handed thread (tighten it to loosen it). Please let us know if this helped.
Lou
Jul 21, 2009 | Poulan Garden
12" craftsman table saw 0 to 45 deg adjustment gears striped
Sears has a site for parts and owner manuals at www.ManageMyHome.com.
It could be something is just loose and out of adjustment so that the teeth were able to slip on the gear. But I've never had a look at one of those to say for sure...oil always helps these things move easier...
Apr 19, 2009 | Saws
The chain will not engage
problem corrected.......I pulled the chain and bar off of the saw and discovered that the chain had seized up in the channel due to some slight "boggering" of some of the inside teeth that ride the groove on the edge of the bar. I filed the damaged metal on both sides of 8-10 damaged teeth (the chain was otherwise in good enough shape to continue to use). I then pulled the whole length of the loose chain through the chain sprocket end of the bar by hand to make sure that I had filed enough of the damaged metal away, before I reassembled the saw. There was slight damage to the drive sprocket, but not enough to prevent the saw from functioning properly. All is now well in the my chainsaw world......and the saw will get a new drive sprocket for Christmas.
Mar 22, 2009 | Poulan Garden
Remington Electric Chain Saw, Model 106890-02 I need a gear replacement for the plastic gear betwen the drive gear and the gear which drives the chain.
Here is a link to the model 106890-02... http://12.153.20.74/manuals/107052-01A.pdf, I would also suggest you contact the parts department at 800-446-1446. They should be able to help you.
Mar 15, 2009 | Remington Garden
Black & Decker 5700 Powershot Forward Action Stapler Logo
118 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
James Ryan
Level 1 Expert
mark gardner
mark gardner
Axel Gringmuth
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
