Question about Health & Beauty
The keyhole to my electric mobility scooter wont work so i pulled it apart and i need to know how to re-wire it without a key, thankyou.
  • 177 Answers
Hi. Most scooters only have two wires to the key lock. All the key does is supply power to the controller, 1 to 2 amps at most. It does not supply the full current to the motors, so only a light duty switch is needed. An automotive toggle switch would do the job. Remember that you will have no security, unless you have a second switch hidden somewhere else on your machine.Good luck. Neil.
Posted on May 27, 2010
How do I replace the headlamp bulb?
Hi, to get to the head light bulb you need to take the tiller head apart by removing the screws that go up from the bottom. The top will lift off but be careful not to pull any wires off. This will give you access to the lamp at the front. make sure you replace the bulb with the same type and voltage.
Jan 13, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
Replacement of rascal 600t headlamp
Hi, To get to the head light bulb you need to take the tiller head apart by removing the screws that go up from the bottom. The top will lift off but be careful not to pull any wires off. This will give you access to the lamp at the front. Make sure you replace the bulb with the same type and voltage.
Rascal 230 wiring diagram
Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
Oct 09, 2014 | Electric Mobility Rascal Scooter...
Can i test to see if a key switch is good on a power scooter
The easiest test to see if you have a bad key switch is to bypass the switch. If the scooter works when you bypass (short across) the switch then you have a bad key switch. The hard part of accomplishing this is to take apart the console and housing of the key switch. Without knowing your model the basic answer is to look at the console housing and look for the screws holding the 2 halves of it together. Remove these screws noting where they go so you can reassemble the console. Once you have the switch exposed on the backside of it you can locate the 2 wires going into the switch. Find the part of these 2 wires which is bare (no insulation) either at the nearest connector or at the switch. Using a paper clip short across these 2 wires, i.e. use the paper clip to connect these 2 points together. If your scooter now works you have a bad key switch.
Oct 24, 2010 | Health & Beauty
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Key broken off in lock cylinder of electric scooter. unable to get key out. How do i replace the cylinder?
hi,I suggust you replace the cylinder, MAPLIN(UK) , RS(US) sell keys lock that what do the job,
When taking the control panel apart please take care of the wiring on the lock, there are normally two wires or two to three on one conection and one on the other.
Regards
GeWiz.
Oct 17, 2009 | Health & Beauty
Health & Beauty Logo
104 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
