Question about Karcher Garden
Karcher 650m micro switch problem
My Karcher 650m pressure washer has stopped working at all. I thoughtthe fuse had gone but having dismantled the black plastic boxcontaining the switch I can press the micro switch and make the washerwork as normal.
Is the pressure switch at fault?
I can't see it moving at all but it looks to me as though the blackplastic rod should rise under water pressure and press the little whitebell crank to activate the micro switch. Am I right and if so why isn'***?
Also where does the V-shaped piece of spring steel fit? It popped outwhen I opened the black unit and I can't see for the life of me whereit fits back in (I guess it provides force against the operation of themanual rotary knob).
2 Suggested Answers
  • 32 Answers
SOURCE: Karcher K6.50 possible pressure switch problem?
sounds like the unloader is stuck onthe machine which pushes against the micro switch.
follow the instructions for a parts diagram.
www.karcher.com
click on europe
then click on international
go to service and spare parts will open, click spare parts
then put in k6.50m on there will be another number on your machine 8 digit , easy way to find your machine, could 10 different models
Posted on Jul 04, 2009
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
New k 3.190, motor does not work
So I just read this very helpful posting.
I dismantled my Karcher 3.190 plugged in the hose and spotted a leak coming from the inside on part of the casing?. When I switched on the pump, it started gushing. It's just out of warranty!
Do I,
A: junk it and slam Kirchner via social media or is it
B; fixable at a reasonable cost.
Opinions, witty replies, and solutions always welcome.
Regards
Wil
Mar 17, 2013 | Karcher Garden
Karcher 1600 pressure washer will not get power. It was working then stopped getting power. It is not that old.
ok im a technician... cheak d power swtich. i think most of karcher power knob switch they got a error problem.
May 30, 2011 | Karcher K2.26 Electric Power Washer
Australian Karcher 2.91 intermitant start
Under the top cover there is a micro switch that sometimes dislodges
This switch is for auto cut off when you release the trigger
Jul 27, 2009 | Karcher K2.26 Electric Power Washer
Karcher B402 pressure washer Motor runs as soon as power supply connected, on/off switch does not seem to make a difference and no pressure at outlet? Was working fine, stopped for half an hour, came back...
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
Jun 22, 2009 | Garden
Karcher pistol gun has broken
i do not think there is a pressure release valve , sounds like the plastic inside the pistol has become brittle and has failed under pressure , you dont say how old the pistols are ? and if you run strong detergents through them .
May 26, 2009 | Karcher PSI Electric Pressure Washer
Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Apr 11, 2009 | Karcher K2.26 Electric Power Washer
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
www.karcher.com
click on europe
Mar 17, 2009 | Garden
Karcher 520M Pressure washer won't operate at high pressure
I had the same problem - good water inlet pressure, no output pressure, even though the lance and handle seemed to be clear and working find.
I found that the electrical switch wasn't being operated correctly by the spill valve and wasn't turning the motor on/off correctly.
Inside the plastic electrical box there is a small white device that presses against the micro switch assembly. Carefully adjust the allen screw perhaps 1/4 turn out or 1/4 turn in to obtain correct operation of the microswitch - you will hear the micro switch clicking in and out when re-assembled. I'm sure they must have a rig to check correct positioning of this screw in the factory!
Hope it helps - mine is working find now and saved me buying another!
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
368 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
