Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Need to replace water hose of LG Refrigerator model LFX25960ST
I have an LG Refrigerator model LFX25960ST and the water line that services the ice maker and cold water has dry rotted. Where can I get a quote to have it replaced or where can I purchase the hose so that I can replace it?
SOURCE: Ice maker quit - LG refrigerator model LFX25960ST, ice maker PN 5989JB0001A
I am a service tech and see this problem often , whats happning is every time you open the left door when water has not frozen. the water splashes into the icemaker and freezes, the only fixto the prolem i have found is to replace icemaker, i have found if you try to thaw out you might get one tray of ice out. thanks
Posted on Jan 13, 2008
  • 210 Answers
SOURCE: LG SXS Refrigerator LSC26905 ice maker
LG has a new ice cube tray to solve this problem.
Part number is 3390JA1150A
Sgt 48
Posted on Jun 03, 2008
huuum
  • 750 Answers
SOURCE: Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Posted on Oct 12, 2008
SOURCE: lg refrigerator LFX25960SW
the answer to the problem from a LG training class is... if the bottom left side of the refer is freezing food the liner has split no fix at this time. some people have beEn able to turn off the ice maker and the food will stop freezing. the ice maker has a fan in the freezer that blows all the cold air up the ice making Cobby.
DO THIS ONLY IF OUTA WARNTEE
for most of you with bad ice makers you could drill a hole in the very bottom of the ice maker towards the front right under the little metal arm in the wight plastic AND DONT DRILL DEEP just enough to put a hole in the outer case then hit it with a blow-dryer for a little bit to remove ice that's blocking the gear on that arm this works 5 outs 10 times
Posted on Oct 29, 2008
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Ice maker is not working - sensor bar rolls up but no ice in ice maker - no water in ine trays
Sound like it is the dual water control only. Try filling ice maker with tap water and then let freeze. If after the ice in the ice maker dumps the cubes into the ice container and does not refill I would think the water control valve is at fault. I see your model had three different choices of water control valves and listed on this page=> Here and in right sidebar about 1/3rd down the page you will see three different water control valves. Here is your Service Manual=> LG LFX25960ST Stainless Steel French Door Refrigerator Try this test first because you mentioned no water in trays. Let me know what results you get and if you have more questions feel free to ask, Thanks, Sea Breeze
Feb 15, 2011 | LG LFX25960ST Stainless Steel French Door...
All of a sudden I can't get water from the door also no water is filling for the ice so I have no ice
You can try replacing the water filter, if that doesnt work it is either going to be a bad watervalve or there is a frozen water line inside the unit
Jan 06, 2011 | LG LFX25960ST Stainless Steel French Door...
My LFX25960st LG stainless refrigerator ice maker isn't working, it'll make a few ice cubes every couple of days and now on the touchpad it says ER IF and i can't touch anything, how can i fix my problem?
Remove the fresh water hose coming into your refrigerator and check the water flow with a small bucket. This actually sounds like a replace water filter error. Some IF error codes break down to Inline Filter.
Jul 31, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice maker is not working. Light goes on but no water fills the maker Model LFD25860TT
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX25960ST Stainless Steel French Door...
Error code er 55? I am not getting water into ice
There are several issues with this ref.
Ref. Lamp cover melting.
Department of energy rework.
Contact LG for service repairs are free.
Jan 04, 2010 | LG LFX25960ST Stainless Steel French Door...
LG RefrigeratorModel LFX25960ST - icemaker has been replaced once
Most ice maker heads cost less than $49 to replace if you get it at a wholesaler. The water quality going to it will effect how long it will last, Reverse Osmosis treated is the best, filters will help some but are not a cure. Your budget is the determining factor in this equation.
Nov 21, 2009 | Microwave Ovens
Ice maker stopped making ice
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | LG LFX25960ST Stainless Steel French Door...
I have the same problem.
Ice in the gears.
Splash from opening and closing the door when liquid water is present seems to be the logical problem.
I had cleared the ice before, thoroughly dried the icemaker and reinstalled it. It worked until I adjusted the icemaker to make large cubes.
I will reinstall it and see how long it last. I will also complain to Sear about the short life of this device.
Dec 27, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
407 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
