Question about Sanyo 09KS51 Mini Split Air Conditioner
Condensation is being pulled off of the evaporator and dripping down the unit.why???
  • 1,383 Answers
ROOM NEEDS TO BE TIGHT OR SEALED A OPEN DOOR WILL CAUSE THIS. OR THE EVAPORATOR DRAIN MAY NEED TO BE CLEANED, FIND OUT WHERE IT DRAINS FROM OUT SIDE AND USE A WET DRY VAC TO **** OUT WHAT MAY BE PLUGGING IT ..... F'N I WAS ANY HELP AT ALL PLEASE VOTE.. JAY
Posted on May 25, 2010
How do i deal with the dripping of water from my Mitsubiishi split system from inside unit? Will putting the unit on 19 and then turning it full bore clear over condensing?
NO
the water is condensation from the humidity in the air turning to water on the cold evaporator core
normally it drips into a tray and drains away outside
if it is inside ( running down the walls it indicates
the drain hole and tube is blocked or the evaporator core is covered in gunk and holding the water up and not dripping where it is designed to
Call an accredited ac specialist shop to clean the fins and drain tube
Jan 06, 2017 | Heating & Cooling
Where should the drip trays be? Condensation dripping into fan housing.
I've seen systems that pull air through the condenser coil into the "squirrel cage" fan and use the heat from the condenser coil to evaporate the water dripped into the fan housing. They're designed to operate that way...
Nov 06, 2015 | Heating & Cooling
Excessive condensation dripping inside refrigerator
Bonjour,
Some refrigerators have heaters mounted in different places around the unit to take care of condensation. If those heaters don't work, you see drips. Another common cause to much frost/ice build up on the freezer evaporator coils or in the area beneath, below or around the evaporator coils. That's usually a sign of incomplete defrost cycle. Another cause could be broken or shifted insulation that's letting very cold air get to the back side of a partition that has warmer air on the other side. The warmer side drips condensation.
Based on the condenser coil cleaning results and not having any temperature data. In your case I would guess incomplete defrost. That leads to defrost timer, defrost heater, defrost termination thermostat and clogged evaporator drain line. Or some combination of the four.
Jul 11, 2012 | Frigidaire Refrigerators
My amana window ac is blowing condesation out the vents. it is still cooling..is this a problem
There is a condensation drain on the unit that is probably plugged. It is natural for air conditioning units to produce condensation as the evaporator coil (the coil/fins that make the air cold as a fan blows air across it ) is much colder than the outside air temperature ( usually between 38 and 55 degrees depending on the unit ). There is a basin or tray at the bottom of the unit that catches the condensation as it drips off the evaporator coil, and there is a drain that allows the water to drain form the unit. If this becomes plugged the water will build up and eventually drip out of the vents of the unit. http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-circuit-and-cycle-diagram.html
In the image, air is blown across the coil in the bottom left section of the picture ( this is the "cold' coil). Condensation can form on this.
Jul 29, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
Water is dripping from the top into the fridge in the back is frozen up and condensation is forming at the top of the fridge ceiling...dripping down.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 10, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Why is there water pooling in my sandwich make up table? My reach in cooler, also?
During the cooling/freezing cycle condensation forms, this drips into a pan and then is evaporated by a heating element.
One of two things could be wrong.....
Your drip pan is clogged
or
your evaporator unit is bad
Hope this helps
Jun 22, 2010 | Randell Refrigeration 111'' Refrigerated 4...
Condensation is dripping down from the freezer into the refridgerator and freezing.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 05, 2009 | Refrigerators
Should there be a condensation hose of some sort. I have a leak and can't find where water is coming from
These units do not have condensation "hoses", they have an evaporator pan than is located under the evaporator coil and catches the condensation and then lets it drip down onto the roof and then off the RV. If your AC is leaking into the inside, remove the inner shroud and feel up into the evaporator area for the pan. If it is full, then the drain holes are plugged. They are not easy to get to. Remove the upper shroud and then remove the front cover over the evaporator. At the base of this area is the pan, on each end is the drain hole. Clean them out and all should be fine.
Hope this helps,
Jeff
Rate me please!!
Jul 07, 2009 | Coleman Mach III Air Conditioner
Dripping from underneath the engine
Dripping condensation from a/c evaporator core is normal. If it wasn't driping from there it would be all over the passenger side floor. While it's dripping, find where the drip is coming from on the firewall and remember where the drain hose is...They often plug up and knowing where it is will help you if it does.
Jun 21, 2009 | 2005 Audi A3
Air conditioner leaks/drips from filter inside travel trailer
Either your 14"x14" a/c gasket is lose on the roof allowing the condensation to flow into your RV or you have a cracked condensation tray under the evaporator. I'm guessing the later
JGRV
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Sanyo 09KS51 Mini Split Air Conditioner Logo
113 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
