Question about Garden
Craftsman zt7000 model 107.27774 - center blade free spins - what could be the problem?
  • 755 Answers
Check the drive pulley! It probably has a sheared key. Or a loose set screw *(where equipped)
Posted on May 25, 2010
Blade does not stop spinning when lever disengaged.
Under seat of tractor theres a plate that says model # it looks like 917. 000000 i need that # please and i can help you with the problem it sounds like the belt isnt disengaging which will cause blades to continue to go.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I replace the Blade Clutch Assembly on a Craftsman mower, model 817.288160?
There is one bolt in center of pto clutch. Its best to have an impact to remove this. If you try to remove with a wrench engine will spin. Remove both belts first. Then simply unplug the PTO, Use impact wrench and remove center bolt and gently pry off. Installation is the reverse order.
Oct 15, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
Replacement engine craftman zt7000
Here you go. Not a bad price, considering.
http://www.smallenginewarehouse.com/RepowerItems.asp?Brand=Craftsman&Model=ZT7000
Smallenginewarehouse.com can fix you right up. Are you sure your engine is shot?
Nov 21, 2009 | Craftsman Garden
Need hydro drive wheel right side for craftsman zt7000
its a zt7000 craftsman homeowners sit down 0 turn mower.mower is made by simplicity 18 hrs koler. since i last posted i had a freind who works on hydro motors for a living break it down clean it and look for visual damage. there was none so it was put back to gether. new gasketts and lubed. after assembly neither side work at all now and makes a grinding noise when levers are put in reverse. left side worked before right side was taken out, left side was never touched. resovours were filled and everything was put back together correctly im positive. im at a loss with this.
Nov 01, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Craftsman 42" Tractor Blade Problem
sounds like either the spindal bearings are shot or maybe the spindal shaft is bent. check for up and down slop at the blades. then turn blades towards each other and check that the heigth lines up. also chec the idler pully to make sure it is not slapping around.
Aug 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I mow with my 42" craftsman tractor it leaves a strip of grass down the center of the cutting path. How do I get rid of this?
Hello:
This is Usually Caused by Worn Blades or a Bad Mandral/Blade Spindle Bearing.
Remove the Deck from Under the Mower.
Remove the Deck Belt.
Check the Mandrals/Blade Spindles for Bad Bearings. Do the Sound Rough when you Spin the Pulleys by Hand? Can you Move the Mandralls/Blade Spindles from Side to Side? If Yes, then the Bearing s Require Replacing.
Look At the Tips of the Cutting Edge of the Blades. You will Se the Tips are Rounded and Not Square. This Condition will cause the Strip in the Center of the Deck.
I have Just Joined this Site. If you Send me the Model Numbers Off the Unit, I can Assist you Better.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
May 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
