Question about Sony Xplod XM-1652Z Car Audio Amplifier
Protection light on 1600 watt class d amp
I have am sony xplod 1600 watt class d amp but the protection light is on now
5 Suggested Answers
SOURCE: brutus 1600 watt hi fonics amp
i have had the same problem with one of my amps that was given to me by a friend and one of the channels were blown. Blowing a channel can cause the protect light to stay on.
Posted on May 08, 2008
  • 631 Answers
SOURCE: Sony Xplod 2-Channel 1000 Watt Amplifier trouble shooting
What's the model number of the amp?
What speakers do you have on the amp?
Are the speakers moving significantly at high volume?
Posted on Sep 14, 2008
  • 18 Answers
SOURCE: sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
Posted on May 27, 2009
  • 65 Answers
SOURCE: sony xplod 1000 watt amp not working
you need a amp kit your battery or alltinator isn't powerful enough to handle the wattage you need a juice can it gives yur battery more power
Posted on Jul 01, 2009
Green light comes on for a sec the red light comes on,1200 watt sony xplod amp 10'' Orion sub,I think the subs right around 3000 watts. What's wrong?:(
Your Sony Xplod amplifier turns on briefly (green light) then possibly senses a mismatch between the nominal output impedance of the amplifier and impedance of your Orion sub and goes into protect mode (red light) to prevent internal damage.
Jul 19, 2014 | Car Audio & Video
Amp going into protection
Is the amp bridged? If you only have one speaker connected to it, I sure hope so. How much power can that speaker safely handle and what is the impedance of the speaker? 2,4,8 ohm? A 1200 watt amp with only one speaker may be too much amp.
Jan 14, 2014 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
On the sony xplod 800 watt amp what are the 2 fuzes in the back for?
The fuses should be 30Amps each and they are there as a protection system in case of a power surge. They will blow before damaging your amplifier. However it is not a 100% fail safe proof.
Feb 04, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Will a sony xplode 100w amp bridged push a 1600w cab? if not what is the best compatible cabinet wattage reccomedation?
100watt amp and 1600 watt cab?? Your amp will run it but a lot of the dynnamics of the speakers won't be there.
Dec 21, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
I hooked this 1000 watt amp up.it turns on but it
Your amp needs to be serviced. Bad protection circuit. Take it to a local car audio shop and have them bench test it first to be sure. Hope this helps.
Sep 26, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod 1200 watt
i had the same ploblem with my amp then i found out i didnt have a good enough ground. Make sure you groung it to your weel well or some part of the frame. Or you mite be running with a fuse thats pushing to much power i use a 100a fuse 5 gage power cord to power my 1200w xplode and my 2 12" kicker comps. Or if your using two diff kind of subs then you amp is confused in why your asking for 500w on one side and 600w on the other this will also make your amp light come on.
Jan 19, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Sony Xplod XM-1652Z Car Audio Amplifier Logo
217 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
