Question about Allen And Heath Xone 92 4-Channel DJ Mixer System
Adding new equipment?
How would I be able to add new equipment to the site? For example my own Allen&Heath pro mixer that I would like to add a manual of?
  • Lasse Saari
    Lasse Saari Apr 07, 2008
    Thanks. But I am more interested in getting a permanent link of the equipment I use (and there are lots!) and then being able to get to their manuals and other resources through that link.
    I wonder if this site is really able to help me with that?
    Thanks anyway..!
  • 682 Answers
Http://www.allen-heath.com/US/dl.asp?file=288
Posted on Apr 07, 2008
  • Anonymous Apr 07, 2008
    as a rule in connection you can connect your dvd or any music source-you will get out from music source and connect it line in mixer or audio in (left and right)in case of stereo connection
SOURCE:
Sir, Iam using the ZED-10FX Allen & Heath mixer. Iam not getting the 48V phanthom power and AUX out from the mixer both Green and RED LED on Phanthom power is not glowing. Iam getting the LED VU m
sOMEHOW YOU BLEW THE 48 v PHANTOM SUPPLY.
Open it up and check power board voltages.
Replace regulator circuit and check for shorts on your mic cables.
PEACE---
Feb 09, 2015 | Allen & Heath ZED-10FX Sound Mixer
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
Midi problem
i think this problem is related with the power of the mixer, see the guide of that mixer and learn how to connect it on right way.
good luck
Feb 17, 2013 | Computers & Internet
Allen and Heath PA 28 is making pulsating sound, lights blink for left and right channels and the sound can be heard throught speakers. It won't go away and it is impossible to use the mixing board. ...
You haven't given us much information... You obviously have some sort of feedback and saturation in process. First thing is to unplug ANY signals into the unit including any inserts and see if problem goes away. If it does, start adding them back in. If it doesn't go away with only the main outputs then VERIFY that you are using BALANCED interconnects to your amps/speakers AND that the mixer AND all of these amps/speakers are powered from the SAME receptacle or power conditioner module. If the BARE mixer with only headphones has the problem, then you have a power supply in the mixer that is squeging.
Nov 03, 2011 | Allen & Heath PA28 Effects Mixer
I would like to buy a case for The Allen & Heath ZED-436 is an audio mixer that gives you 32 mono inputs plus 2 dual stereo channels. Which one do you recommend that can fit it well.Please send me...
Cases are being sold on Ebay, new, from several sources, and if you can't find one specifically listed for your unit, contact the sellers as they custom build them. That is a big unit... expect to pay around $150 to $200 for an ATA type case for it.
Here is an example for a Heath/Allen 420. http://cgi.ebay.com/ATA-CASE-ALLEN-HEATH-ZED-420-ZED-420-ZED420-MIXER-/400127078772?pt=LH_DefaultDomain_0&hash=item5d296eb174
I have bought from them before myself and there are others on Ebay so shop around... You can contact the companies and ask for a specific one and DO compare the size to your unit that they specify as all the companies do not accept returns...
Aug 14, 2011 | Allen & Heath AH ZED 436 32...
Hi there. When I power on the mxer it blinks all the signal light and the power light with the sound level indicator repeatedly untill i turn the unit off, I cannot use the mixer and would like to know...
Make sure ALL interconnected equipment is powered by the same receptacle or power conditioner. Do NOT use separate recptacles at opposite ends of a romm for example. Run power extension back with your snake. There may be a failure in the unit. Since it is so new, exercise your warranty... do NOT risk voiding the warranty. Do verify that your power is clean.
May 13, 2011 | Allen & Heath AH ZED 436 32...
I have an allen and heath Xone 22 Mixer. Its great, except due to the lack of a power switch I pulled the ac adapter/power cord out too many times and now it has a really bad, loose connection. It works,...
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Apr 11, 2011 | Allen & Heath Xone-22 2 Channel Dj Mixer
Hi there my allen heath mixer is weired this
If you use analog outputs and inputs try to clear of it really is your mixer and not one of the inputs. If the inputs are good your mainboard could be a bit dusty or you have a loose contact. If you have a mixer with internal interface your audio stream from your computer might be the problem.
Jan 23, 2010 | Music
Allen And Heath Xone 92 4-Channel DJ Mixer System Logo
148 people viewed this question
Top Allen Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Allen Audio Player and Recorder Expert? Answer questions, earn points and help others
