Question about Toshiba Satellite Pro U400-S1001V Notebook PC
How to get Toshiba NB100 service manual?
I am in need to dismantel my Toshiba NB100 laptop to clean it
how I can do so without missing it up?
  • Anonymous Mar 14, 2014
    black screen after removing ram
  • 93 Answers
All screws on the bottom of the nb 100 series are the same except the one under the battery and holding the cover strip in the center, put them in a small glass or cup and remove the screen that has two screws in hinge base above and two below, being careful not to break the wireless cable con la tecnología dehow to get Toshiba NB100 service manual? - small-logo.png
Posted on May 27, 2010
HOW DO I PRINT FROM MY TOSHIBA NB100 ON MY LEXMARK 7300 PRINTER
Download the driver installer here:
http://www.xpvistaworld.com/lexmark_7300_series_1239.htm
Install the driver on your laptop and your Lexmark should work after that.
Jul 09, 2014 | Lexmark International Lexmark 2500 Series
Toshiba NB100 do not work from AC plug
try pulling the battery off and running unit straight through cable
Jan 30, 2013 | Toshiba Computers & Internet
Toshiba nb100
http://www.notebookcheck.net/Toshiba-NB100.12668.0.html
1) First thing to check is the AC adapter (Charger) power output.
It is 19 Volts (DC)
Suggest use a multimeter to check.
An economical, yet good enough for this test, multimeter, can be purchased for as little as $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
http://www.youtube.com/watch?v=LnTxs0o5CJA
In the above video ->
DO NOT TEST THE POWER LINE CORD -> GOING INTO THE AC ADAPTER (Charger) 0:00 to 3:58 in video.
-> TOO DANGEROUS. Take the power cord to a pro to test it.
AGAIN -> DO NOT TEST THE POWER CORD
110 to 220 volts will give you a BAD SHOCK to -> FATAL <-
(Can kill you)
For the second part of the test starting at 3:58, it is okay.
You will be testing for 19 Volts -> DC
If the voltage shown is not at least 17.1 Volts (DC), (90 percent),
the AC adapter is no good.
Replace.
AC adapter checks out?
Then it's time to check the DC Power Jack.
(DC_IN on the laptop. The jack on the laptop you plug the AC adapter into )
2) Remove the Battery. With a non-metallic object, gently see if you can wiggle the center pin of the DC Power Jack around.
ANY perceptible movement means a bad DC Power jack.
Good news is that it is Not soldered to the motherboard. It is attached to wires, that are attached to a small white plug in connector. (DC Power Jack is connected to a harness),
http://www.amazon.com/TOSHIBA-NB100-NETBOOK-CABLE-HARNESS/dp/B005J9CEXS
(You can click on the photo to enlarge)
Once removed, you can check it for continuity with the multimeter, set to OHM. (1K)
Or have it checked.
The DC Power Jack harness, plugs into the CN5 connector on the motherboard,
http://www.aliexpress.com/store/product/MOTHERBOARD-FOR-TOSHIBA-NB100-NB105-V000155020-6050A2213401-100-TSTED-GOOD/202172_485947825.html
Looking at the motherboard in the photo, you will see two green squares. The middle square is the Processor.
The green square to the right is what I want you to look at. Specifically, the small white connector to the right of it.
(The green square is a chipset. It has a white triangle < pointing to the Top/Right corner)
Put your mouse cursor on the photo. (Magnified view)
Go to the small white connector to the right, of the green square
I indicated above.
Has a small white arrow ( > ) pointing to the Top/Left corner of the white connector.
This is the CN5 connector on the motherboard.
If the DC Power Jack harness is not the problem, then the problem is Power MOSFET's on the motherboard, and or Capacitors.
(Ceramic SMD capacitor/s)
[Just basic info. Pertains to an HP laptop. Just want you to see about Power MOSFET's,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html ]
Choice is yours, whether you wish to have bad electronic components replaced, or replace the motherboard.
May be more feasible for you to replace the motherboard.
Toshiba Netbook PC NB100 Service Manual, (Free. No junk attached),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go to the subheading -> Mini Notebook. (5th one down)
Left-click on the blue -> NB100
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (NB100) it may take up to 30 seconds, before the first page comes up.
In the Bookmarks menu to the left, click on the + sign to the left of -
Chapter 4.
In the list click on ->
4.7 System Board, DC-IN, RJ-45 Cable and Bluetooth Card
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 25, 2012 | Toshiba Computers & Internet
Missing operating system toshiba nb100
I wonder if you actually have a Mac OS on your Toshiba laptop, as this is nearly impossible (only for experts): 1) If you purchased from an authorized seller (I doubt it) - return the laptop for replacement.
2) If you can't claim anything from the seller - install the operation system yourself. If your feel being an expert, here are instructions for installing Mas OS on your PC: http://wiki.osx86project.org/wiki/index.php/Installation_Guides and user experience: http://www.insanelymac.com/forum/lofiversion/index.php/t144614.html
3) However, I would recommend you to download, copy to DVD and install a Linux Ubuntu distribution instead: http://www.ubuntu.com/desktop/get-ubuntu/download or purchase Windows from any computer store.
Mar 05, 2011 | Toshiba Computers & Internet
I have a Toshiba NB100 notebook and the alpha on
Hello
Unfortunately my friend this is the big problem with that laptop,small keyboard and not good back lighting,the only think you can do is to buy keyboard stickers or a keyboard
Here is a link to ebay for stickers
http://shop.ebay.com/?_kw=keyboard%20stickers&_fcid=80&_localstpos=&_sticky=1&_stpos=&gbr=1
Jan 13, 2010 | Computers & Internet
Toshiba Satellite Pro U400-S1001V Notebook PC Logo
1,178 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
