Need hdmi video card for gateway 510x i have one pci slot open No APG slot I want to us my 42'' hdtv as monitor. Also, looks like the gatewat slots on on the wrong side. Can I flip the card over?
  • Sheryl Jun 15, 2010
    Thanks but I tried PCIE did not fit. I have PCI also does not fit. Maybe it's just not in the video cards for me.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 38 Answers
I'm guessing you have a PCI-Express slot in your computer. In that case you can buy almost any PCI-Express video card these days and have it output to your HDTV.
Newegg's list of HDCP-capable video cards
What you're really looking for isn't a "HDMI" capable video card really, since all video card with some sort of digital connection, DVI, DisplayPort, can all be converted to HDMI using a converter even if you doesn't have a HDMI connector built in.
What you need is a card that is HDCP-compatible, which is the encoding/encryption for HD content output. Almost all new video cards now have it. So you shouldn't have a problem.
As far as inserting the card... they're often placed differently depending on chasis and motherboard, but you shouldn't have any issues with that either.
Posted on May 28, 2010
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
What video cards fit into a gateway profile 6
You won't ba able to fit a video card in this computer. Because it is a all-in-one PC.
May 26, 2012 | Gateway Computers & Internet
The video prt where you plug in the monitor cord is broke off. What can I do so my monitor works?
Is the port broke off the computer or the back of the monitor? If its off the computer and you have expansion slot available on the motherboard you can get a video card. Make sure you get the right type as a PCI video card will not fit in a PCI express or APG type slot.
Aug 08, 2011 | Computers & Internet
What is the second hdmi port surrounded in orange on the back of my gateway dx4320-17 do? it doesnt work when connected to my monitor so is it an hdmi input? and would i be able to connect my ps3 to it and...
I presume by second HDMI that you've got an additional Video Card in one of the expension slots (Item 10 at the link below) with another HDMI output
http://support.gateway.com/s/desktop/2010/gateway/dx/dx4840/DX4840rv.shtml
The HDMI surrounded by orange is an ouput but if you've got and additional Video Card then this build in HDMI would normally be deactivated.
Sometimes the problem relates to the screen resolution you've got your computer set to as this needs to match your Monitors HDMI Input i.e.1280x720 or 1920x1080 as detailed at the link below.
http://hd.engadget.com/2006/02/08/how-to-connect-your-pc-to-your-hdtv/
Jul 26, 2011 | Gateway DX4300-03 Desktop PC
I was just wondering where to put my Graphics card in my computer :S In one of these white slots? The only number i could find on it was E210882
I depends upon the type of graphics card you have purchased. The white slots are PCI expansion slots
and if the there is a longer slot in the middle of the motherboard next to the PCI slots, then it will be a AGP expansion slot.
APG graphics card are better graphics cards and these slots are designed for these graphics cards.
Dec 20, 2010 | Dell (E210882) Motherboard
Gateway 510x r4 installing a video card
Gateway Support, and the main support page for the Gateway 510x R4 desktop computer. (It's a Legacy computer)
http://support.gateway.com/s/PC/510Series/2900456/2900456nv.shtml
Left-click on - Components
Now left-click on -
2521362 - Intel (Midway 2 GV) Motherboard No CPU RO
(Under the Motherboards heading)
Here you will see a photo of the Gateway 510X R4 motherboard.
[You can enlarge this photo for more clarity in viewing.
Right-click on the photo.
Now left-click on - Save Image As
In the File name: box, you will see - 2521362nv
This will be the file name you will look for.
You can add to this file name, so that it is easier to find.
Left-click twice after the v in 2521362nv
Make one space with your space bar.
Type Gateway 510X motherboard.
Now go below to the right, and click on - Save.
This will go to your My Pictures folder. Open My Pictures, (Start>My Pictures), and double-click on the motherboard photo.
Now go below, and left-click on the Zoom In icon.
The Plus ( + ) sign]
In the main menu left-click on Specifications.
Scroll down to the heading - Expansion Capabilities
Here you will see listed -
Three PCI Bus add-in card connectors (SMbus routed to PCI bus connector 2)
This means you have a PCI slot for a graphics card slot.
Looking at the motherboard photo, you will see three white PCI slots.
In the motherboard photo, these are the three white long slots, towards the bottom left.
Use any open, unused PCI slot. Doesn't matter which one you use.
You need a graphics card that fits in a PCI slot.
These are examples of PCI graphics cards,
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
My suggestion would be for a graphics card like this,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5071671&CatId=3670
(You have a 250 Watt power supply in your computer. In the Components list, it is listed under Power Supplies. You have one of those 250 Watt power supply's)
I wouldn't suggest spending more, or going for a better graphics card.
The single core Intel Pentium 4 (3.0GHz) processor, won't handle newer games that require a dual core processor.
No reason to waste your money.
Any questions please state in a Comment.
JCV
May 20, 2010 | Gateway 510 X (10272197) PC Desktop
What graphic card is compatible for my pc?? i have HP PAVILION, g3660d, 2 GB RAM, WINDOW VISTA home basic.I want to play games like Left 4 dead, COD 4....
Well... Windows Vista can be installed on anything. I'm not familiar with your particular PC, but there are two ends to the problem. A) Plug in to PC end. Here there are the PCI-bus, and PCI-E standards. PCI-E comes in many flavors, a tiny tiny connection (1 lane), and a wide connection (>1 lanes? don't remember 8?). Open your PC box and look at the slot closest to the CPU, that is typically the graphics card expansion slot. Take a picture (if you have a camera), note if this slot is "different" from the other slots... it is likey to be. Then you can google PCI-E and PCI connectors to see if you can match them up. If you have a *NEW* pc it's likely you have a PCI-E bus. This is the *faster* solution.
2) Card to monitor. There are multiple ports on many of the new PC graphics cards... from oldest to newest VGA - This is a DB-9 type connector... looks like a oval but is longer on one side than the other. (i.e. not a rectangle). This is the oldest standard. DVI - This is an oval connection.. You can get DVI to VGA adaptors, and some video cards come with them. This will have a series of pins and a "+" cross pin connection on it. HDMI -- The coolest and typically includes sound for direct connection to HDTV. But your monitor may not have this type of port.
So if your looking for a card, look for one that is either PCI-E or PCI based on how old your PC is, and also look at what types of video output connectors it has.. VGA/DVI or HDMI. Most of the newer cards will have HDMI and DVI output with a VGA adaptor. But some don't.
Then... there is the case of a particular card having "issues" with the game you want. If you have time... pick a particular card, then google for "my favorite game" [replace the game with your game name" and the video card with the word problems... to see if anyone has had problems with that particular combo. (I never do that... :()
Jul 07, 2009 | HP GeForce 8400GS Graphics Card - nVIDIA...
Gateway GX7018E / T6420 = swap video cards for a test?????
No you cant, the gateway GX7018E uses integrated graphics like the T6420. You will have to buy a cheap PCI or PCI-E graphics card to test it out.
Jan 02, 2009 | E-Machines T6420 PC Desktop
I could have swore I purchased an apg 4x video card, that's what my V2 premier,( L4S5MG3 mother board)requires.The nivdia Gforce6200 is 8x/4x will this work? Don't want to open, till sure.
8x and 4x means that the video card is an AGP ( not apg) typo i guess.
If it was PCI or PCI Express, it would say so on the box. Look at *********** board, the video card slot will usually have AGP prined next to it. Also, your old video card may have a sticker on it that says its a BLAH BLAH card with SUCH AND SUCH Megabytes of ram and thats its a AGP or PCI, PCI EXPRESS.
Once you know for sure that the card will work, open her up, install and enjoy.
Jun 12, 2008 | Computers & Internet
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
